Alienware 17 R4 Fan Shroud Replacement
    1. Alienware 17 R4 Fan Shroud Replacement, Base Cover: step 1, image 1 of 1
      • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
      • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
      • The M2x3 screw (1.9 mm) does not come out completely.
      Ask FixBot
    2. Alienware 17 R4 Fan Shroud Replacement: step 2, image 1 of 2 Alienware 17 R4 Fan Shroud Replacement: step 2, image 2 of 2
      • Pull the base cover up to remove it.
      • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
      • Removing the cover may require some force.
      Ask FixBot
    1. Alienware 17 R4 Fan Shroud Replacement, Hard Disk Drive (HDD): step 3, image 1 of 3 Alienware 17 R4 Fan Shroud Replacement, Hard Disk Drive (HDD): step 3, image 2 of 3 Alienware 17 R4 Fan Shroud Replacement, Hard Disk Drive (HDD): step 3, image 3 of 3
      • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
      • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
      • Failure to remove the battery connector cable properly may damage other parts of the laptop.
      Ask FixBot
    2. Alienware 17 R4 Fan Shroud Replacement: step 4, image 1 of 3 Alienware 17 R4 Fan Shroud Replacement: step 4, image 2 of 3 Alienware 17 R4 Fan Shroud Replacement: step 4, image 3 of 3
      • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
      Ask FixBot
    3. Alienware 17 R4 Fan Shroud Replacement: step 5, image 1 of 3 Alienware 17 R4 Fan Shroud Replacement: step 5, image 2 of 3 Alienware 17 R4 Fan Shroud Replacement: step 5, image 3 of 3
      • Gently lift the HDD cable to disconnect it from the laptop.
      Ask FixBot
    4. Alienware 17 R4 Fan Shroud Replacement: step 6, image 1 of 2 Alienware 17 R4 Fan Shroud Replacement: step 6, image 2 of 2
      • Pull the hard drive up to remove.
      Ask FixBot
    1. Alienware 17 R4 Fan Shroud Replacement, RAM: step 7, image 1 of 3 Alienware 17 R4 Fan Shroud Replacement, RAM: step 7, image 2 of 3 Alienware 17 R4 Fan Shroud Replacement, RAM: step 7, image 3 of 3
      • Move the metal sidings outward to release the RAM card.
      Ask FixBot
    2. Alienware 17 R4 Fan Shroud Replacement: step 8, image 1 of 1
      • Slide the RAM card out towards yourself to remove it.
      • Repeat the same step for the RAM card above.
      • Slide the RAM card out carefully to avoid damaging it.
      Ask FixBot
    1. Alienware 17 R4 Fan Shroud Replacement, Wi-Fi card: step 9, image 1 of 1
      • Locate the WI-FI card.
      Ask FixBot
    2. Alienware 17 R4 Fan Shroud Replacement: step 10, image 1 of 2 Alienware 17 R4 Fan Shroud Replacement: step 10, image 2 of 2
      • Peel back plastic cover of wi-fi card.
      • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
      Ask FixBot
    3. Alienware 17 R4 Fan Shroud Replacement: step 11, image 1 of 3 Alienware 17 R4 Fan Shroud Replacement: step 11, image 2 of 3 Alienware 17 R4 Fan Shroud Replacement: step 11, image 3 of 3
      • Gently undo the clips attached to the wi-fi card.
      • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
      Ask FixBot
    4. Alienware 17 R4 Fan Shroud Replacement: step 12, image 1 of 2 Alienware 17 R4 Fan Shroud Replacement: step 12, image 2 of 2
      • Locate the cables that connect the wi-fi card.
      • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
      Ask FixBot
    1. Alienware 17 R4 Fan Shroud Replacement, Solid State Drive: step 13, image 1 of 2 Alienware 17 R4 Fan Shroud Replacement, Solid State Drive: step 13, image 2 of 2
      • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
      Ask FixBot
    2. Alienware 17 R4 Fan Shroud Replacement: step 14, image 1 of 2 Alienware 17 R4 Fan Shroud Replacement: step 14, image 2 of 2
      • Slide the solid state drive towards yourself to prevent damage to the card.
      Ask FixBot
    1. Alienware 17 R4 Fan Shroud Replacement, Fan Shroud: step 15, image 1 of 3 Alienware 17 R4 Fan Shroud Replacement, Fan Shroud: step 15, image 2 of 3 Alienware 17 R4 Fan Shroud Replacement, Fan Shroud: step 15, image 3 of 3
      • Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
      Ask FixBot
    2. Alienware 17 R4 Fan Shroud Replacement: step 16, image 1 of 2 Alienware 17 R4 Fan Shroud Replacement: step 16, image 2 of 2
      • Insert the plastic opening tool under the fan shroud to slowly lift it up.
      • Repeat process on the middle and opposite side.
      Ask FixBot
    3. Alienware 17 R4 Fan Shroud Replacement: step 17, image 1 of 2 Alienware 17 R4 Fan Shroud Replacement: step 17, image 2 of 2
      • Firmly lift the plastic opening tool and pull the fan shroud towards you.
      • This will take a large amount of force and will not come out easily the first time.
      • Careful not to tear out the piece causing damage to the fan shroud
      Ask FixBot
3 other people completed this guide.
Hector Mendez III
1,352 Reputation
8 Guides authored
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 99
All Time: 7,239
