Alienware 17 R3 Hard Drive Replacement
    1. Alienware 17 R3 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Turn the computer off.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
      • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
      Ask FixBot
    2. Alienware 17 R3 Hard Drive Replacement: step 2, image 1 of 1
      • Unscrew and remove the two 4mm Phillips #1 screws from the cover.
      Ask FixBot
    3. Alienware 17 R3 Hard Drive Replacement: step 3, image 1 of 1
      • Pull up and slide the cover off.
      Ask FixBot
    4. Alienware 17 R3 Hard Drive Replacement: step 4, image 1 of 2 Alienware 17 R3 Hard Drive Replacement: step 4, image 2 of 2
      • Unplug the black wire with the yellow tag to disconnect the battery.
      Ask FixBot
    5. Alienware 17 R3 Hard Drive Replacement: step 5, image 1 of 2 Alienware 17 R3 Hard Drive Replacement: step 5, image 2 of 2
      • Unscrew and remove the four 3mm Phillips #1 screws holding the hard drive in place.
      Ask FixBot
    6. Alienware 17 R3 Hard Drive Replacement: step 6, image 1 of 2 Alienware 17 R3 Hard Drive Replacement: step 6, image 2 of 2
      • Unscrew and remove the four 2mm Phillips #1 screws holding the casing together.
      Ask FixBot
    7. Alienware 17 R3 Hard Drive Replacement: step 7, image 1 of 1
      • Remove the plug from the Hard Drive.
      Ask FixBot
    8. Alienware 17 R3 Hard Drive Replacement: step 8, image 1 of 1
      • Lift the Hard Drive out.
      Ask FixBot
8 other people completed this guide.
Jonathon Tschurwald
878 Reputation
4 Guides authored
UW Tacoma, Team 1-1, Rose Winter 2017 Member of UW Tacoma, Team 1-1, Rose Winter 2017
UWT-ROSE-W17S1G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 130
All Time: 5,467
