Up to 20% off select tools
Alienware 17 R3 Battery Replacement
Views: 38K
View statistics:
Past 24 Hours:
11
Past 7 Days:
54
Past 30 Days:
254
All Time:
38,266
Comments: 6
6 guide comments.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the battery for your Alienware 17 R3. Be sure you have all the required tools before you begin.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    1. Alienware 17 R3 Battery Replacement, Battery: step 1, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Turn the computer off.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
      • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
      Ask FixBot
    2. Alienware 17 R3 Battery Replacement: step 2, image 1 of 1
      • Unscrew and remove the two 4mm Phillips #1 screws from the cover.
      • Remember to put the screws in a safe place so you can find them all during re-assembly.
      Ask FixBot
    3. Alienware 17 R3 Battery Replacement: step 3, image 1 of 1
      • Pull up and slide the cover off.
      Ask FixBot
    4. Alienware 17 R3 Battery Replacement: step 4, image 1 of 2 Alienware 17 R3 Battery Replacement: step 4, image 2 of 2
      • Unplug the black wire with the yellow tag to disconnect the battery.
      Ask FixBot
    5. Alienware 17 R3 Battery Replacement: step 5, image 1 of 2 Alienware 17 R3 Battery Replacement: step 5, image 2 of 2
      • Unscrew and remove the four 3mm Phillips #1 screws holding the hard drive in place.
      Ask FixBot
    6. Alienware 17 R3 Battery Replacement: step 6, image 1 of 2 Alienware 17 R3 Battery Replacement: step 6, image 2 of 2
      • Unscrew and remove the four 2mm Phillips #1 screws holding the casing together.
      Ask FixBot
    7. Alienware 17 R3 Battery Replacement: step 7, image 1 of 2 Alienware 17 R3 Battery Replacement: step 7, image 2 of 2
      • Remove the plug from the hard drive.
      • Lift the hard drive out and set aside.
      Ask FixBot
    8. Alienware 17 R3 Battery Replacement: step 8, image 1 of 1
      • Unscrew the one Phillips #1 screw holding down the bottom of the M.2 chip.
      • Pull the M.2 chip straight out of its socket.
      Ask FixBot
    9. Alienware 17 R3 Battery Replacement: step 9, image 1 of 1
      • Unscrew and remove the eight 3mm Phillips #1 screws (located in areas labeled "P").
      Ask FixBot
    10. Alienware 17 R3 Battery Replacement: step 10, image 1 of 1
      • Carefully disconnect the four flex cables.
      • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
      Ask FixBot
    11. Alienware 17 R3 Battery Replacement: step 11, image 1 of 1
      • Remove the six 4mm Phillips #1 screws on the side and the two 10mm Phillips #1 screws on the top.
      Ask FixBot
    12. Alienware 17 R3 Battery Replacement: step 12, image 1 of 1
      • Flip over the laptop and open it.
      • Insert the spudger along the edges of the laptop and gently pry upward to lift the keyboard panel.
      Ask FixBot
    13. Alienware 17 R3 Battery Replacement: step 13, image 1 of 1
      • Remove the six 4mm Phillips #1 screws holding the battery in place.
      Ask FixBot
    14. Alienware 17 R3 Battery Replacement: step 14, image 1 of 3 Alienware 17 R3 Battery Replacement: step 14, image 2 of 3 Alienware 17 R3 Battery Replacement: step 14, image 3 of 3
      • Unplug the two sets of wires from the motherboard.
      Ask FixBot
    15. Alienware 17 R3 Battery Replacement: step 15, image 1 of 1
      • Lift out the battery pack.
      Ask FixBot
22 other people completed this guide.
Author
with
Jonathon Tschurwald
887 Reputation
4 Guides authored
UW Tacoma, Team 1-1, Rose Winter 2017 Member of UW Tacoma, Team 1-1, Rose Winter 2017
UWT-ROSE-W17S1G1
3 Members
48 Guides authored
6 Guide Comments
Hi ! Nice DIY . Is it possible to disassemble the battery pack and change the cell inside ?
francois tremblay - Reply Share
Hi, please edit step 10. There a 4th ribbon has to be pulled.
Nevertheless a very good manual.
Steffen Bönisch - Reply Share
Hi Steffen,
Thanks for the tip! I edited step 10 to correct the mistake.
Arthur Shi - Reply Share
Very helpful and concise. Worked very well for me. Many Thanks
Ragufta Khan - Reply Share
After putting everything back together I found my didn't HDD work. It was simply that the other end of the HDD cable had become disconnected.
I'd recommend disconnecting this before removing the HDD housing so it doesn't snag (it's actually shown as disconnected in step 10).
Dom Parrott - Reply Share
Past 24 Hours: 11
Past 7 Days: 54
Past 30 Days: 254
All Time: 38,266
