Alienware 17 R2 Palm Rest Replacement
    1. Alienware 17 R2 Palm Rest Replacement, Disconnecting the Keyboard Cable: step 1, image 1 of 1
      • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Lift the latches and disconnect the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable from the system board.
      Ask FixBot
    2. Alienware 17 R2 Palm Rest Replacement, Removing Screws: step 2, image 1 of 1
      • Remove the screws that secure the palm-rest assembly to the computer base.
      Ask FixBot
    3. Alienware 17 R2 Palm Rest Replacement, Lifting the Computer Base: step 3, image 1 of 1
      • Lift the computer base slightly and push the palm-rest assembly through the slot on the computer base to release the tabs on the palm-rest assembly.
      Ask FixBot
    4. Alienware 17 R2 Palm Rest Replacement, Turning the Computer Over: step 4, image 1 of 1
      • Turn the computer over and open the display as far as possible.
      Ask FixBot
    5. Alienware 17 R2 Palm Rest Replacement, Prying the Edges: step 5, image 1 of 1
      • Using a plastic scribe, pry up along the edges of the palm rest assembly.
      Ask FixBot
    6. Alienware 17 R2 Palm Rest Replacement, Lifting the Palm-Rest Assembly: step 6, image 1 of 1
      • Gently lift the palm-rest assembly and turn it over.
      Ask FixBot
      • Peel the tape that secures the power-button cable to the system board.
      Ask FixBot
      • Disconnecting the power-board cable from the system board.
      Ask FixBot
    7. Alienware 17 R2 Palm Rest Replacement, Lifting the Palm-Rest Assembly: step 9, image 1 of 1
      • Lift the palm-rest assembly off the computer base.
      Ask FixBot
    8. Alienware 17 R2 Palm Rest Replacement, Removing the Power-Button Board: step 10, image 1 of 1
      • Remove the power-button board.
      Ask FixBot
    9. Alienware 17 R2 Palm Rest Replacement, Status-Light Board Removal: step 11, image 1 of 1
      • Remove the status-light board.
      Ask FixBot
      • Remove the keyboard bracket.
      Ask FixBot
    10. Alienware 17 R2 Palm Rest Replacement, Touch Pad Removal: step 13, image 1 of 1
      • Remove the touch pad.
      Ask FixBot
    11. Alienware 17 R2 Palm Rest Replacement, Replacing: step 14, image 1 of 1
      • Replace the touch pad.
      • Replace the keyboard.
      • Replace the status-light board.
      • Replace the power-button board.
      Ask FixBot
      • Connect the power-button cable to the system board.
      Ask FixBot
      • Adhere the tape that secures the power button cable to the system board.
      Ask FixBot
      • Slide the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable through the slot on the computer base.
      Ask FixBot
      • Align the palm-rest assembly on the computer base and snap it into place.
      Ask FixBot
      • Close the display and turn the computer over.
      Ask FixBot
    12. Alienware 17 R2 Palm Rest Replacement, Replace the Screws: step 20, image 1 of 1
      • Replace the screws that secure the palm-rest assembly to the computer base.
      Ask FixBot
      • Slide the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable into their respective connectors and press down the latches to secure the cables to the system board.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 108
All Time: 1,443
