Up to 20% off select tools
Alienware 17 R2 Memory Modules Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
82
All Time:
1,193
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 4 - 8 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Modules.
    1. Alienware 17 R2 Memory Modules Replacement, Popping up Memory Module: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Remove the base panel.
      • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
      Ask FixBot
    2. Alienware 17 R2 Memory Modules Replacement, Remove Memory Module: step 2, image 1 of 2 Alienware 17 R2 Memory Modules Replacement, Remove Memory Module: step 2, image 2 of 2
      • Slide and remove the memory module from the memory-module slot.
      Ask FixBot
    3. Alienware 17 R2 Memory Modules Replacement, Aligining the Notch: step 3, image 1 of 1
      • Align the notch on the new memory module with the tab on the memory- module slot.
      Ask FixBot
    4. Alienware 17 R2 Memory Modules Replacement, Installing Memory Module: step 4, image 1 of 2 Alienware 17 R2 Memory Modules Replacement, Installing Memory Module: step 4, image 2 of 2
      • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
      • If you do not hear the click, remove the memory module and reinstall it.
      Ask FixBot
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 82
All Time: 1,193
