Alienware 17 R2 Hard Drive Replacement
    1. Alienware 17 R2 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Make sure the laptop is unplugged from any power source.
      • Put the laptop facing down on a hard surface.
      Ask FixBot
    2. Alienware 17 R2 Hard Drive Replacement: step 2, image 1 of 3 Alienware 17 R2 Hard Drive Replacement: step 2, image 2 of 3 Alienware 17 R2 Hard Drive Replacement: step 2, image 3 of 3
      • Unscrew the two 6mm screws on the bottom side of the laptop.
      • Lift up the back cover and slide towards you.
      Ask FixBot
    3. Alienware 17 R2 Hard Drive Replacement: step 3, image 1 of 2 Alienware 17 R2 Hard Drive Replacement: step 3, image 2 of 2
      • Locate the Hard Drive
      Ask FixBot
    4. Alienware 17 R2 Hard Drive Replacement: step 4, image 1 of 1
      • Remove the screws that connect the SSD Bay to the laptop
      Ask FixBot
    5. Alienware 17 R2 Hard Drive Replacement: step 5, image 1 of 1
      • Unscrew the three screws holding the hard drive
      Ask FixBot
    6. Alienware 17 R2 Hard Drive Replacement: step 6, image 1 of 2 Alienware 17 R2 Hard Drive Replacement: step 6, image 2 of 2
      • Unscrew the four screws on the long sides of the hard drive casing
      Ask FixBot
    7. Alienware 17 R2 Hard Drive Replacement: step 7, image 1 of 3 Alienware 17 R2 Hard Drive Replacement: step 7, image 2 of 3 Alienware 17 R2 Hard Drive Replacement: step 7, image 3 of 3
      • Now that the hard drive casing is off, carefully unplug the hard drive from the laptop
      • Your hard drive has now been successfully removed from your device
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 34
Past 30 Days: 112
All Time: 2,239
