Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓Use this guide to replace the battery on an Alienware 17 R2 laptop.
Your laptop may need a new battery if it will not hold a charge or will not turn on without being connected to the charger. While replacing the laptop battery might fix this issue, it may not be a permanent solution. Please be cautious if the battery appears to be swollen.
Some knowledge and understanding of computer motherboards will be beneficial, however, minimal repair skill is required. Before beginning, make sure to power down the computer completely and disconnect it from any external power source.
Be sure the laptop is turned off.
Unplug the laptop from the power adapter.
Place the laptop face down on a hard surface.
6 other people completed this guide.
3 Guide Comments
Many thanks for a decent write up. My only observation was that I don't know why there was a need to unplug the power to the palm rest and fully remove it? You have access to the battery once the palm rest is lifted. Good write up non the less
I’m confused, my laptop is Alienware M17x R2 but the shape is different.
