Alienware 15 R2 Hard Drive Replacement
    1. Alienware 15 R2 Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 Alienware 15 R2 Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 Alienware 15 R2 Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Place laptop upside down with the hinge facing you, then remove the two 9.0 mm Phillips #0 screws located in the center of the rear panel.
      • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
      • Be sure to use your Anti-Static wrist strap for this process. Hard drives are susceptible to static damage!
      Ask FixBot
    2. Alienware 15 R2 Hard Drive Replacement: step 2, image 1 of 2 Alienware 15 R2 Hard Drive Replacement: step 2, image 2 of 2
      • Use the iFixit opening tool to disconnect the battery cable.
      Ask FixBot
    3. Alienware 15 R2 Hard Drive Replacement: step 3, image 1 of 2 Alienware 15 R2 Hard Drive Replacement: step 3, image 2 of 2
      • Use the T9 Torx bit to remove the screws on the hard drive cover.
      Ask FixBot
    4. Alienware 15 R2 Hard Drive Replacement: step 4, image 1 of 2 Alienware 15 R2 Hard Drive Replacement: step 4, image 2 of 2
      • Firmly pull on the plastic tab to remove connector from motherboard and remove the hard drive from it's slot.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 81
All Time: 2,335
