This teardown is not a repair guide. To repair your Oversized Giant Bluetooth Headset Speaker, use our service manual.
  1. AliExpress giant airpod teardown, Open it up: step 1, image 1 of 2 AliExpress giant airpod teardown, Open it up: step 1, image 2 of 2
    • Flip your giant headphone over onto the "back" and unscrew the 4 Philips head screws with your PH2 screwdriver
    • Pry the plastic piece with the screwholes off the rest of the device, starting from the stem of the headphone.
    Ask FixBot
  2. AliExpress giant airpod teardown, Remove the speaker: step 2, image 1 of 2 AliExpress giant airpod teardown, Remove the speaker: step 2, image 2 of 2
    • Pull the tip of of the headphone off the the remaining stem piece. Now, the speaker can simply be pulled to separate the glue and remove it from this top plastic piece
    Ask FixBot
  3. AliExpress giant airpod teardown, Remove the board: step 3, image 1 of 3 AliExpress giant airpod teardown, Remove the board: step 3, image 2 of 3 AliExpress giant airpod teardown, Remove the board: step 3, image 3 of 3
    • Using your PH00 screwdriver, undo the single screw from the green circuit board. Lift the PCB out of the headphone shell.
    • Now disconnect the COLOUR-CODED connectors for the speaker and battery. these are the same connection type, so do not mix them up when reassembling it or you could seriously damage the device. red connector to red, white connector to white. In my case, the board connector slid right out with the cable, so use the image as reference to put them back
    Ask FixBot
Dylan
323 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 104
All Time: 2,029
