Alcatel Pop 4 Plus Rear Camera Replacement
    1. Alcatel Pop 4 Plus Rear Camera Replacement, Battery: step 1, image 1 of 2 Alcatel Pop 4 Plus Rear Camera Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
      Ask FixBot
    2. Alcatel Pop 4 Plus Rear Camera Replacement: step 2, image 1 of 2 Alcatel Pop 4 Plus Rear Camera Replacement: step 2, image 2 of 2
      • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
      Ask FixBot
    3. Alcatel Pop 4 Plus Rear Camera Replacement: step 3, image 1 of 1
      • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
      Ask FixBot
    4. Alcatel Pop 4 Plus Rear Camera Replacement: step 4, image 1 of 2 Alcatel Pop 4 Plus Rear Camera Replacement: step 4, image 2 of 2
      • Use the flat end of the spudger disconnect the battery from the motherboard.
      • Use the flat end of the spudger tool to pry out the battery.
      Ask FixBot
    1. Alcatel Pop 4 Plus Rear Camera Replacement, Rear Camera: step 5, image 1 of 1
      • Use the flat end of the spudger tool to remove the connector.
      Ask FixBot
    2. Alcatel Pop 4 Plus Rear Camera Replacement: step 6, image 1 of 1
      • Pry out the camera with the pointy end of the spudger tool.
      Ask FixBot
Maalik Poleon
202 Reputation
2 Guides authored
USF Tampa, Team S20-G6, Passmore Spring 2018 Member of USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 18
Past 30 Days: 59
All Time: 628
