Alcatel Pop 4 Plus Motherboard Replacement
    1. Alcatel Pop 4 Plus Motherboard Replacement, Battery: step 1, image 1 of 2 Alcatel Pop 4 Plus Motherboard Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
      Ask FixBot
    2. Alcatel Pop 4 Plus Motherboard Replacement: step 2, image 1 of 2 Alcatel Pop 4 Plus Motherboard Replacement: step 2, image 2 of 2
      • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
      Ask FixBot
    3. Alcatel Pop 4 Plus Motherboard Replacement: step 3, image 1 of 1
      • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
      Ask FixBot
    4. Alcatel Pop 4 Plus Motherboard Replacement: step 4, image 1 of 2 Alcatel Pop 4 Plus Motherboard Replacement: step 4, image 2 of 2
      • Use the flat end of the spudger disconnect the battery from the motherboard.
      • Use the flat end of the spudger tool to pry out the battery.
      Ask FixBot
    1. Alcatel Pop 4 Plus Motherboard Replacement, Motherboard: step 5, image 1 of 2 Alcatel Pop 4 Plus Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
      • Slide the ribbon cable out of the socket.
      Ask FixBot
    2. Alcatel Pop 4 Plus Motherboard Replacement: step 6, image 1 of 2 Alcatel Pop 4 Plus Motherboard Replacement: step 6, image 2 of 2
      • Use the flat end of a spudger to disconnect the ribbon cable.
      Ask FixBot
    3. Alcatel Pop 4 Plus Motherboard Replacement: step 7, image 1 of 2 Alcatel Pop 4 Plus Motherboard Replacement: step 7, image 2 of 2
      • Using the flat end of the spudger to disconnect the ribbon cable.
      Ask FixBot
    4. Alcatel Pop 4 Plus Motherboard Replacement: step 8, image 1 of 2 Alcatel Pop 4 Plus Motherboard Replacement: step 8, image 2 of 2
      • Using the flat end of the spudger, disconnect the camera from the motherboard.
      Ask FixBot
    5. Alcatel Pop 4 Plus Motherboard Replacement: step 9, image 1 of 1
      • Use the flat end of the spudger to pry off the motherboard.
      Ask FixBot
2 other people completed this guide.
Pieter Molenaar
253 Reputation
1 Guide authored
USF Tampa, Team S20-G6, Passmore Spring 2018 Member of USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Members
72 Guides authored
1 Guide Comment
Hi
I got my Alcatel Pop 4+ checked and it's Power IC was faulty. How can I replace it
I'm looking for the specific IC used in it if I can get any help regarding it.
NINJA WARRIORS - Reply Share
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 67
All Time: 1,496
