Alcatel Pop 4 Plus Headphone Jack Replacement
  1. Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: step 1, image 1 of 3 Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: step 1, image 2 of 3 Alcatel Pop 4 Plus Headphone Jack Replacement, Headphone Jack: step 1, image 3 of 3
    • Begin by removing the back of the phone. Press your nail or a thin object in the bottom right-hand corner of the phone and gently press to release the back of the phone from the front.
  2. Alcatel Pop 4 Plus Headphone Jack Replacement: step 2, image 1 of 3 Alcatel Pop 4 Plus Headphone Jack Replacement: step 2, image 2 of 3 Alcatel Pop 4 Plus Headphone Jack Replacement: step 2, image 3 of 3
    • Remove seventeen 1.2mm screws from the phone's mid-frame using the Phillips #000 screwdriver.
  3. Alcatel Pop 4 Plus Headphone Jack Replacement: step 3, image 1 of 2 Alcatel Pop 4 Plus Headphone Jack Replacement: step 3, image 2 of 2
    • Once the screws have been taken out, remove the mid-frame protecting the phone's electronics by using a fingernail or tool to pry it off.
  4. Alcatel Pop 4 Plus Headphone Jack Replacement: step 4, image 1 of 3 Alcatel Pop 4 Plus Headphone Jack Replacement: step 4, image 2 of 3 Alcatel Pop 4 Plus Headphone Jack Replacement: step 4, image 3 of 3
    • Disconnect the battery from the motherboard and remove it.
  5. Alcatel Pop 4 Plus Headphone Jack Replacement: step 5, image 1 of 2 Alcatel Pop 4 Plus Headphone Jack Replacement: step 5, image 2 of 2
    • Unhook the USB ribbon from the motherboard.
  6. Alcatel Pop 4 Plus Headphone Jack Replacement: step 6, image 1 of 2 Alcatel Pop 4 Plus Headphone Jack Replacement: step 6, image 2 of 2
    • Disconnect the phone's ribbon cable from the mother board.
  7. Alcatel Pop 4 Plus Headphone Jack Replacement: step 7, image 1 of 2 Alcatel Pop 4 Plus Headphone Jack Replacement: step 7, image 2 of 2
    • Disconnect the ribbon cable that binds the two motherboards together.
  8. Alcatel Pop 4 Plus Headphone Jack Replacement: step 8, image 1 of 2 Alcatel Pop 4 Plus Headphone Jack Replacement: step 8, image 2 of 2
    • Remove the phone's rear camera from the motherboard.
  9. Alcatel Pop 4 Plus Headphone Jack Replacement: step 9, image 1 of 1
    • Insert a flat tool at the edge of the phone and gently lift to remove the motherboard.
  10. Alcatel Pop 4 Plus Headphone Jack Replacement: step 10, image 1 of 3 Alcatel Pop 4 Plus Headphone Jack Replacement: step 10, image 2 of 3 Alcatel Pop 4 Plus Headphone Jack Replacement: step 10, image 3 of 3
    • Locate the phone's headphone jack on the motherboard.
  11. Alcatel Pop 4 Plus Headphone Jack Replacement: step 11, image 1 of 3 Alcatel Pop 4 Plus Headphone Jack Replacement: step 11, image 2 of 3 Alcatel Pop 4 Plus Headphone Jack Replacement: step 11, image 3 of 3
Garett Marler
202 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 326
