Up to 20% off select tools
Alcatel Pop 4 Plus Front Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
59
All Time:
818
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • Phillips #000 Screwdriver
    4.9
Introduction
Go to step 1 ↓
If your front facing camera just isn't taking good pictures anymore then it might be time to replace it! This guide will show you how to replace your camera in just a few simple steps. You'll have to remove the the first and secondary covers to get to the motherboard. Then you'll have to disengage the connectors to the motherboard so that you can remove it and access the front camera.
    1. Alcatel Pop 4 Plus Front Camera Replacement, Battery: step 1, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
      Ask FixBot
    2. Alcatel Pop 4 Plus Front Camera Replacement: step 2, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement: step 2, image 2 of 2
      • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
      Ask FixBot
    3. Alcatel Pop 4 Plus Front Camera Replacement: step 3, image 1 of 1
      • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
      Ask FixBot
    4. Alcatel Pop 4 Plus Front Camera Replacement: step 4, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement: step 4, image 2 of 2
      • Use the flat end of the spudger disconnect the battery from the motherboard.
      • Use the flat end of the spudger tool to pry out the battery.
      Ask FixBot
    1. Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: step 5, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: step 5, image 2 of 2
      • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
      • Slide the ribbon cable out of the socket.
      Ask FixBot
    2. Alcatel Pop 4 Plus Front Camera Replacement: step 6, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement: step 6, image 2 of 2
      • Use the flat end of a spudger to disconnect the ribbon cable.
      Ask FixBot
    3. Alcatel Pop 4 Plus Front Camera Replacement: step 7, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement: step 7, image 2 of 2
      • Using the flat end of the spudger to disconnect the ribbon cable.
      Ask FixBot
    4. Alcatel Pop 4 Plus Front Camera Replacement: step 8, image 1 of 2 Alcatel Pop 4 Plus Front Camera Replacement: step 8, image 2 of 2
      • Using the flat end of the spudger, disconnect the camera from the motherboard.
      Ask FixBot
    5. Alcatel Pop 4 Plus Front Camera Replacement: step 9, image 1 of 1
      • Use the flat end of the spudger to pry off the motherboard.
      Ask FixBot
    1. Alcatel Pop 4 Plus Front Camera Replacement, Front Camera: step 10, image 1 of 1
      • Disconnect the camera from the motherboard using the flattened of a spudger.
      Ask FixBot
Author
with
peter achanccaray
123 Reputation
1 Guide authored
USF Tampa, Team S20-G6, Passmore Spring 2018 Member of USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 59
All Time: 818
