Alcatel OneTouch Evolve Secondary Panel Removal
    1. Alcatel OneTouch Evolve Secondary Panel Removal, Locate the access tab: step 1, image 1 of 1
      • This will be an opening with enough space to insert the flat head of the plastic opening tool.
      • It will be located on the bottom right of the phone
      Ask FixBot
    2. Alcatel OneTouch Evolve Secondary Panel Removal, Place the flat head end of the pry tool into the tab: step 2, image 1 of 3 Alcatel OneTouch Evolve Secondary Panel Removal, Place the flat head end of the pry tool into the tab: step 2, image 2 of 3 Alcatel OneTouch Evolve Secondary Panel Removal, Place the flat head end of the pry tool into the tab: step 2, image 3 of 3
      • Rotate the pry tool 90 degrees until the panel lifts up.
      • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
      Ask FixBot
    1. Alcatel OneTouch Evolve Secondary Panel Removal, Identify the Battery: step 3, image 1 of 1
      • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
      Ask FixBot
    2. Alcatel OneTouch Evolve Secondary Panel Removal, Removing the battery: step 4, image 1 of 2 Alcatel OneTouch Evolve Secondary Panel Removal, Removing the battery: step 4, image 2 of 2
      • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
      Ask FixBot
    1. Alcatel OneTouch Evolve Secondary Panel Removal, Locate Screws Holding the Secondary Panel in Place: step 5, image 1 of 1
      • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
      Ask FixBot
    2. Alcatel OneTouch Evolve Secondary Panel Removal, Remove Screws: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Unscrew each screw, counter-clockwise (left), until each one has been removed.
      • If necessary, use tweezers to fully remove the screws from the device.
      • Remove battery before lifting off the panel.
      Ask FixBot
    3. Alcatel OneTouch Evolve Secondary Panel Removal, Prying the Panel Off: step 7, image 1 of 3 Alcatel OneTouch Evolve Secondary Panel Removal, Prying the Panel Off: step 7, image 2 of 3 Alcatel OneTouch Evolve Secondary Panel Removal, Prying the Panel Off: step 7, image 3 of 3
      • Access the small pry tool in the tool kit
      • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
      • Rotate the pry tool 90 degrees until part of the panel lifts up
      • All areas need to be fully risen off before the panel can be removed.
      • Do not use the opening tool to pry open the device near the power button or near the volume button.
      Ask FixBot
4 other people completed this guide.
Brendan Egan
2,491 Reputation
5 Guides authored
UMass Dartmouth, Team 4-5, Miles Fall 2014 Member of UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 97
All Time: 2,543
