Alcatel OneTouch Elevate Rear Camera Replacement
    1. Alcatel OneTouch Elevate Rear Camera Replacement, Battery: step 1, image 1 of 3 Alcatel OneTouch Elevate Rear Camera Replacement, Battery: step 1, image 2 of 3 Alcatel OneTouch Elevate Rear Camera Replacement, Battery: step 1, image 3 of 3
      • Locate the small indent on the lower left corner.
      • Use your fingers or a small plastic opening tool to lift the back cover off.
      Ask FixBot
    2. Alcatel OneTouch Elevate Rear Camera Replacement: step 2, image 1 of 3 Alcatel OneTouch Elevate Rear Camera Replacement: step 2, image 2 of 3 Alcatel OneTouch Elevate Rear Camera Replacement: step 2, image 3 of 3
      • Locate the indent between the battery and your phone.
      • Use your finger or a small plastic opening tool to lift the battery free.
      Ask FixBot
    1. Alcatel OneTouch Elevate Rear Camera Replacement, Motherboard: step 3, image 1 of 3 Alcatel OneTouch Elevate Rear Camera Replacement, Motherboard: step 3, image 2 of 3 Alcatel OneTouch Elevate Rear Camera Replacement, Motherboard: step 3, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the nine screws from the phone.
      Ask FixBot
    2. Alcatel OneTouch Elevate Rear Camera Replacement: step 4, image 1 of 1
      • Place an iFixit opening tool between the screen and the back cover and pry it open.
      Ask FixBot
    3. Alcatel OneTouch Elevate Rear Camera Replacement: step 5, image 1 of 2 Alcatel OneTouch Elevate Rear Camera Replacement: step 5, image 2 of 2
      • Disconnect the camera from the mother board with your prying tool.
      Ask FixBot
    4. Alcatel OneTouch Elevate Rear Camera Replacement: step 6, image 1 of 3 Alcatel OneTouch Elevate Rear Camera Replacement: step 6, image 2 of 3 Alcatel OneTouch Elevate Rear Camera Replacement: step 6, image 3 of 3
      • Remove both of the cables located on the bottom left corner of the phone.
      Ask FixBot
    5. Alcatel OneTouch Elevate Rear Camera Replacement: step 7, image 1 of 2 Alcatel OneTouch Elevate Rear Camera Replacement: step 7, image 2 of 2
      • Remove the volume and power button using your prying tool.
      • Go underneath the bronze plate with your prying tool and carefully pry it off.
      Ask FixBot
    6. Alcatel OneTouch Elevate Rear Camera Replacement: step 8, image 1 of 1
      • Remove this piece that is to the right of the camera with your prying tool.
      Ask FixBot
    7. Alcatel OneTouch Elevate Rear Camera Replacement: step 9, image 1 of 2 Alcatel OneTouch Elevate Rear Camera Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Remove these two pieces by using your tweezers.
      • Carefully pull them off. There will be a black flap where you can place your tweezers to pull.
      Ask FixBot
    8. Alcatel OneTouch Elevate Rear Camera Replacement: step 10, image 1 of 1
      • Using the prying tool, go in-between the phone.
      • Carefully pry it off.
      Ask FixBot
    1. Alcatel OneTouch Elevate Rear Camera Replacement, Back of Camera: step 11, image 1 of 1
      • Find the camera.
      Ask FixBot
    2. Alcatel OneTouch Elevate Rear Camera Replacement: step 12, image 1 of 1
      • Gently place the opening tool head as close as possible to the edge.
      Ask FixBot
    3. Alcatel OneTouch Elevate Rear Camera Replacement: step 13, image 1 of 1
      • Flip the camera up carefully and slowly.
      Ask FixBot
    4. Alcatel OneTouch Elevate Rear Camera Replacement: step 14, image 1 of 1
      • Take the old camera out and replace it with the replacement.
      • Gently press on the camera and wait for it to stick back to the phone.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Son Bao Luong
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 66
All Time: 541
