Alcatel One Touch Idol 3 Battery Replacement
    1. Alcatel One Touch Idol 3 Battery Replacement, Battery: step 1, image 1 of 3 Alcatel One Touch Idol 3 Battery Replacement, Battery: step 1, image 2 of 3 Alcatel One Touch Idol 3 Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the sim tray by inserting a sim removal tool and then pulling it out.
      Ask FixBot
    2. Alcatel One Touch Idol 3 Battery Replacement: step 2, image 1 of 3 Alcatel One Touch Idol 3 Battery Replacement: step 2, image 2 of 3 Alcatel One Touch Idol 3 Battery Replacement: step 2, image 3 of 3
      • Remove the back cover by moving around its perimeter with a thin object that can fit.
      • Eventually you will be able to pry open the back cover.
      • Although a razor is depicted, we recommend using ESD-safe pry tools instead.
      Ask FixBot
    3. Alcatel One Touch Idol 3 Battery Replacement: step 3, image 1 of 2 Alcatel One Touch Idol 3 Battery Replacement: step 3, image 2 of 2
      • Remove the protective sticker from the battery connection.
      Ask FixBot
    4. Alcatel One Touch Idol 3 Battery Replacement: step 4, image 1 of 2 Alcatel One Touch Idol 3 Battery Replacement: step 4, image 2 of 2
      • Disconnect the battery's connection to the motherboard by lifting it upwards.
      Ask FixBot
    5. Alcatel One Touch Idol 3 Battery Replacement: step 5, image 1 of 2 Alcatel One Touch Idol 3 Battery Replacement: step 5, image 2 of 2
      • Add a small amount of isopropyl alcohol around the sides of the battery to soften the adhesive.
      • Take care to not get isopropyl alcohol on any other parts of the phone.
      Ask FixBot
    6. Alcatel One Touch Idol 3 Battery Replacement: step 6, image 1 of 3 Alcatel One Touch Idol 3 Battery Replacement: step 6, image 2 of 3 Alcatel One Touch Idol 3 Battery Replacement: step 6, image 3 of 3
      • Pry out the battery by leveraging an object under the battery and lifting it upwards.
      • Although a razor is depicted, we recommend using ESD-safe pry tools instead. A razor could easily puncture the battery and create a hazard.
      Ask FixBot
Eric Lopez
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 83
All Time: 664
