Alcatel One Touch Fierce Battery Replacement
    1. Alcatel One Touch Fierce Battery Replacement, Rear Case: step 1, image 1 of 2 Alcatel One Touch Fierce Battery Replacement, Rear Case: step 1, image 2 of 2
      • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      Ask FixBot
    1. Alcatel One Touch Fierce Battery Replacement, Midframe: step 2, image 1 of 3 Alcatel One Touch Fierce Battery Replacement, Midframe: step 2, image 2 of 3 Alcatel One Touch Fierce Battery Replacement, Midframe: step 2, image 3 of 3
      • Remove the 11 Phillips #000 screws.
      • The midframe should lift free.
      Ask FixBot
    1. Alcatel One Touch Fierce Battery Replacement, Battery: step 3, image 1 of 2 Alcatel One Touch Fierce Battery Replacement, Battery: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tip of a spudger to pull back the yellow tape covering the battery connector.
      • Use a pair of tweezers to pull the battery connector from its port.
      • Be careful not to tear the battery from its connection.
      Ask FixBot
23 other people completed this guide.
Jonathan Ruiz
1,322 Reputation
2 Guides authored
6 Guide Comments
Hello.. please suggest how to remove battery of one touch FLASH.
It is non removable battery.. Since my mobile is unable to reboot I need to remove back cover to make it work
Kapil Chaudhari - Reply Share
remove sd and sim cards with power off…same as fierce 4/pop 4 all Phillips 000 screws come out then carefully unsnap inner back case half from main case starting on opposite side of power button.with each snap undone, carefully pry case half’s apart using plastic tool or credit card. once apart, unfasten battery connector. power up phone before re assembly.once it works power off and reverse instructions to assemble.
john vanlandingham - Reply Share
If the battery is so easy to remove, why is it called “non-removable”?
fbanks47 - Reply Share
how do you reboot after battery replacement
Alan Duncan - Reply Share
How do I transfer google files from my alcotel phone to my computer
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 125
All Time: 76,052
