Alcatel One Touch Evolve 2 Rear Speaker Replacement
  1. Alcatel One Touch Evolve 2 Rear Speaker Replacement, Back Frame: step 1, image 1 of 3 Alcatel One Touch Evolve 2 Rear Speaker Replacement, Back Frame: step 1, image 2 of 3 Alcatel One Touch Evolve 2 Rear Speaker Replacement, Back Frame: step 1, image 3 of 3
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
    Ask FixBot
  2. Alcatel One Touch Evolve 2 Rear Speaker Replacement: step 2, image 1 of 1
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
    Ask FixBot
  3. Alcatel One Touch Evolve 2 Rear Speaker Replacement: step 3, image 1 of 1
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
    Ask FixBot
  4. Alcatel One Touch Evolve 2 Rear Speaker Replacement: step 4, image 1 of 3 Alcatel One Touch Evolve 2 Rear Speaker Replacement: step 4, image 2 of 3 Alcatel One Touch Evolve 2 Rear Speaker Replacement: step 4, image 3 of 3
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
    Ask FixBot
  5. Alcatel One Touch Evolve 2 Rear Speaker Replacement: step 5, image 1 of 2 Alcatel One Touch Evolve 2 Rear Speaker Replacement: step 5, image 2 of 2
    • Pull the rear frame off with your hands.
    Ask FixBot
  6. Alcatel One Touch Evolve 2 Rear Speaker Replacement, Rear Speaker: step 6, image 1 of 1
    • Gently loosen the rear speaker by using one of the plastic opening tools and prying the speaker off its metal base.
    • The adhesive holding the speaker to the base may be strong depending on the age and condition of the phone. Adjust your prying force if necessary.
    Ask FixBot
  7. Alcatel One Touch Evolve 2 Rear Speaker Replacement: step 7, image 1 of 1
    • De-solder the black and red wires of the speaker using a soldering tool.
    • If you need instructions on how to solder/desolder electronic connections, here is a link to the Soldering Technique Guide
    Ask FixBot
Andrew Bai
634 Reputation
5 Guides authored
IUPUI, Team 1-3, Baechle Spring 2017 Member of IUPUI, Team 1-3, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G3
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 59
All Time: 730
