Alcatel One Touch Evolve 2 LCD Screen Replacement
    1. Alcatel One Touch Evolve 2 LCD Screen Replacement, Back Frame: step 1, image 1 of 3 Alcatel One Touch Evolve 2 LCD Screen Replacement, Back Frame: step 1, image 2 of 3 Alcatel One Touch Evolve 2 LCD Screen Replacement, Back Frame: step 1, image 3 of 3
      • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
      • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
      • Be gentle when prying so as to not wear out the tool.
      Ask FixBot
    2. Alcatel One Touch Evolve 2 LCD Screen Replacement: step 2, image 1 of 1
      • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
      Ask FixBot
    3. Alcatel One Touch Evolve 2 LCD Screen Replacement: step 3, image 1 of 1
      • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
      Ask FixBot
    4. Alcatel One Touch Evolve 2 LCD Screen Replacement: step 4, image 1 of 3 Alcatel One Touch Evolve 2 LCD Screen Replacement: step 4, image 2 of 3 Alcatel One Touch Evolve 2 LCD Screen Replacement: step 4, image 3 of 3
      • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
      Ask FixBot
    5. Alcatel One Touch Evolve 2 LCD Screen Replacement: step 5, image 1 of 2 Alcatel One Touch Evolve 2 LCD Screen Replacement: step 5, image 2 of 2
      • Pull the rear frame off with your hands.
      Ask FixBot
    1. Alcatel One Touch Evolve 2 LCD Screen Replacement, Main Circuit Board: step 6, image 1 of 2 Alcatel One Touch Evolve 2 LCD Screen Replacement, Main Circuit Board: step 6, image 2 of 2
      • Use a plastic opening tool to pop the speaker press-fit connector free.
      • Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
      Ask FixBot
    2. Alcatel One Touch Evolve 2 LCD Screen Replacement: step 7, image 1 of 1
      • Use a plastic opening tool to lift the front camera press-fit connector free.
      Ask FixBot
    3. Alcatel One Touch Evolve 2 LCD Screen Replacement: step 8, image 1 of 1
      • Insert one of the plastic opening tools into any side of the main circuit board and gently pry it loose from the front cover. Repeat the process all around the circuit board.
      Ask FixBot
    4. Alcatel One Touch Evolve 2 LCD Screen Replacement: step 9, image 1 of 1
      • Detach the main circuit board from the front cover.
      Ask FixBot
    1. Alcatel One Touch Evolve 2 LCD Screen Replacement, LCD Screen: step 10, image 1 of 1
      • Gently pry off the digitizer from the main circuit board using a spudger
      Ask FixBot
    2. Alcatel One Touch Evolve 2 LCD Screen Replacement: step 11, image 1 of 3 Alcatel One Touch Evolve 2 LCD Screen Replacement: step 11, image 2 of 3 Alcatel One Touch Evolve 2 LCD Screen Replacement: step 11, image 3 of 3
      • Carefully separate the digitizer from circuit board.
      • Using your hands, gently remove the ribbon connecting the digitizer to the circuit board.
      Ask FixBot
2 other people completed this guide.
Akira Nakaza
427 Reputation
3 Guides authored
IUPUI, Team S5-G5, Baechle Fall 2017 Member of IUPUI, Team S5-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G5
3 Members
36 Guides authored
1 Guide Comment
Merci de nous donner l’équivalant de numériseur d'écran tactile pour Alcatel One Touch Evolve 2 4037T,l’origine est obsolète.
salut
labadi.abdelmalek - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 98
All Time: 1,757
