Introduction
This guide will teach you how to replace the front speaker of the Alcatel OneTouch Evolve 2.
Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
Use a plastic opening tool to pop the speaker press-fit connector free.
Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
Use a spudger to pry out the speaker from the front panel using the prongs on the speaker.
