Alcatel One Touch Evolve 2 Front Camera Replacement
    1. Alcatel One Touch Evolve 2 Front Camera Replacement, Back Frame: step 1, image 1 of 3 Alcatel One Touch Evolve 2 Front Camera Replacement, Back Frame: step 1, image 2 of 3 Alcatel One Touch Evolve 2 Front Camera Replacement, Back Frame: step 1, image 3 of 3
      • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
      • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
      • Be gentle when prying so as to not wear out the tool.
      Ask FixBot
    2. Alcatel One Touch Evolve 2 Front Camera Replacement: step 2, image 1 of 1
      • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
      Ask FixBot
    3. Alcatel One Touch Evolve 2 Front Camera Replacement: step 3, image 1 of 1
      • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
      Ask FixBot
    4. Alcatel One Touch Evolve 2 Front Camera Replacement: step 4, image 1 of 3 Alcatel One Touch Evolve 2 Front Camera Replacement: step 4, image 2 of 3 Alcatel One Touch Evolve 2 Front Camera Replacement: step 4, image 3 of 3
      • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
      Ask FixBot
    5. Alcatel One Touch Evolve 2 Front Camera Replacement: step 5, image 1 of 2 Alcatel One Touch Evolve 2 Front Camera Replacement: step 5, image 2 of 2
      • Pull the rear frame off with your hands.
      Ask FixBot
    1. Alcatel One Touch Evolve 2 Front Camera Replacement, Main Circuit Board: step 6, image 1 of 2 Alcatel One Touch Evolve 2 Front Camera Replacement, Main Circuit Board: step 6, image 2 of 2
      • Use a plastic opening tool to pop the speaker press-fit connector free.
      • Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
      Ask FixBot
    2. Alcatel One Touch Evolve 2 Front Camera Replacement: step 7, image 1 of 1
      • Use a plastic opening tool to lift the front camera press-fit connector free.
      Ask FixBot
    3. Alcatel One Touch Evolve 2 Front Camera Replacement: step 8, image 1 of 1
      • Insert one of the plastic opening tools into any side of the main circuit board and gently pry it loose from the front cover. Repeat the process all around the circuit board.
      Ask FixBot
    4. Alcatel One Touch Evolve 2 Front Camera Replacement: step 9, image 1 of 1
      • Detach the main circuit board from the front cover.
      Ask FixBot
    1. Alcatel One Touch Evolve 2 Front Camera Replacement, Front Camera: step 10, image 1 of 1
      • Slip the front camera out of its designated hole.
      Ask FixBot
3 other people completed this guide.
Andrew Bai
634 Reputation
5 Guides authored
IUPUI, Team 1-3, Baechle Spring 2017 Member of IUPUI, Team 1-3, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 100
All Time: 725
