Introduction
Replacing the Alcatel Lively Jitterbug Smart3's motherboard is a significant repair that should only be performed if the device has suffered severe internal damage, such as liquid exposure, or a critical hardware failure that cannot be resolved through software resets or minor part replacements. As the motherboard is the "central brain" for the phone's processing, memory, and connectivity, replacing it will result in the loss of all data stored on the device. Therefore, replacing the motherboard should only be done if the device has suffered severe internal damage or hardware failure.
Use your fingernail or small pry tool to gently lift around the edges of the phone until the back cover pops off.
Gently detach the three connections on the top of the battery.
Use a pair of tweezers to pull the battery connector from its port.
