Up to 20% off select tools
Alcatel Jitterbug Smart Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
72
All Time:
836
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the logic board in your Alcatel Jitterbug Smart
    1. Alcatel Jitterbug Smart Camera Replacement, Rear Camera: step 1, image 1 of 2 Alcatel Jitterbug Smart Camera Replacement, Rear Camera: step 1, image 2 of 2
      • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
      • Lift open case by the corner nearest the divot and remove it from the phone.
      Ask FixBot
    2. Alcatel Jitterbug Smart Camera Replacement: step 2, image 1 of 2 Alcatel Jitterbug Smart Camera Replacement: step 2, image 2 of 2
      • Remove the 13 1 mm Phillips screws with JIS #000 Screwdriver.
      Ask FixBot
    3. Alcatel Jitterbug Smart Camera Replacement: step 3, image 1 of 2 Alcatel Jitterbug Smart Camera Replacement: step 3, image 2 of 2
      • Gently pry off the Mid frame from the phone using a Metal Spudger.
      Ask FixBot
    4. Alcatel Jitterbug Smart Camera Replacement: step 4, image 1 of 2 Alcatel Jitterbug Smart Camera Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use the Plastic Opening tools to gently dislodge the broken camera from the inside of the phone.
      • Use a tweezers to pull the camera connector from its port.
      • Be careful not to tear the camera from its connection.
      Ask FixBot
Author
with
Gavin Le
523 Reputation
3 Guides authored
USF Tampa, Team S11-G4, Cheng Spring 2018 Member of USF Tampa, Team S11-G4, Cheng Spring 2018
USFT-CHENG-S18S11G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 72
All Time: 836
