Alcatel Go Flip V Flip Phone Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
54
All Time:
325
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The 2 megapixel fixed focus rear camera is mounted in the display assembly and can be replaced.
Tools
    1. Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Screen Cover: step 1, image 1 of 1
      • Heat the screen cover with an iOpener, a heat gun or even a hair dryer to soften the adhesive holding it to the display frame.
      • Use caution with a heat gun as you could easily melt the plastic screen cover.
      Ask FixBot
    2. Alcatel Go Flip V Flip Phone Camera Replacement: step 2, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement: step 2, image 2 of 2
      • Insert a curved razor blade under the screen cover to pry it open.
      Ask FixBot
    3. Alcatel Go Flip V Flip Phone Camera Replacement: step 3, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement: step 3, image 2 of 2
      • Use plastic picks to separate the adhesive. Metal is not advised as it will scratch the plastic material the cover is made of. Add more heat as needed.
      Ask FixBot
    4. Alcatel Go Flip V Flip Phone Camera Replacement: step 4, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement: step 4, image 2 of 2
      • Remove the plastic screen cover.
      Ask FixBot
    5. Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Rear Cover: step 5, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Rear Cover: step 5, image 2 of 2
      • Remove the four 3.5mm Phillips screws holding the rear cover in place.
      Ask FixBot
    6. Alcatel Go Flip V Flip Phone Camera Replacement: step 6, image 1 of 3 Alcatel Go Flip V Flip Phone Camera Replacement: step 6, image 2 of 3 Alcatel Go Flip V Flip Phone Camera Replacement: step 6, image 3 of 3
      • Starting at the hinge side, insert a metal opening tool between the rear cover and the display's frame.
      • Continue down the side of the phone, releasing clips as you go.
      Ask FixBot
    7. Alcatel Go Flip V Flip Phone Camera Replacement: step 7, image 1 of 3 Alcatel Go Flip V Flip Phone Camera Replacement: step 7, image 2 of 3 Alcatel Go Flip V Flip Phone Camera Replacement: step 7, image 3 of 3
      • Work your way across the bottom and up the other side.
      • And finally the rear cover is free.
      Ask FixBot
    8. Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Camera: step 8, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement, Remove the Camera: step 8, image 2 of 2
      • Using a spudger, disconnect the camera's flex cable.
      Ask FixBot
    9. Alcatel Go Flip V Flip Phone Camera Replacement: step 9, image 1 of 2 Alcatel Go Flip V Flip Phone Camera Replacement: step 9, image 2 of 2
      • Remove the camera from the display.
      Ask FixBot
Jerry Wheeler
101,635 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 54
All Time: 325
