Alcatel Go Flip 4 Speaker Replacement
    1. Alcatel Go Flip 4 Speaker Replacement, Battery: step 1, image 1 of 3 Alcatel Go Flip 4 Speaker Replacement, Battery: step 1, image 2 of 3 Alcatel Go Flip 4 Speaker Replacement, Battery: step 1, image 3 of 3
      • Insert a spudger into the notch on the back cover and gently pry upward until you hear a soft click, indicating the back has begun to separate.
      • Continue prying around the edges until the cover is fully removed.
      Ask FixBot
    2. Alcatel Go Flip 4 Speaker Replacement: step 2, image 1 of 3 Alcatel Go Flip 4 Speaker Replacement: step 2, image 2 of 3 Alcatel Go Flip 4 Speaker Replacement: step 2, image 3 of 3
      • Insert a spudger into the midframe cutout and pry up to release the battery.
      • Remove the battery.
      Ask FixBot
    1. Alcatel Go Flip 4 Speaker Replacement, Speaker: step 3, image 1 of 3 Alcatel Go Flip 4 Speaker Replacement, Speaker: step 3, image 2 of 3 Alcatel Go Flip 4 Speaker Replacement, Speaker: step 3, image 3 of 3
      • Use a JIS #00 screwdriver to remove all nine 4.4 mm screws that secure the midframe.
      Ask FixBot
    2. Alcatel Go Flip 4 Speaker Replacement: step 4, image 1 of 2 Alcatel Go Flip 4 Speaker Replacement: step 4, image 2 of 2
      • Run the spudger under the midframe to pry it away from the rest of the phone.
      • Be very careful when removing the midframe as too much strain can cause it to snap.
      • Set the midframe aside.
      Ask FixBot
    3. Alcatel Go Flip 4 Speaker Replacement: step 5, image 1 of 2 Alcatel Go Flip 4 Speaker Replacement: step 5, image 2 of 2
      • Place the spudger under the speaker in the midframe and pry up.
      • There is adhesive on the speaker but you should be able to remove it without heat.
      • Remove the speaker from the midframe.
      Ask FixBot
Dulcemaria Ramirez
641 Reputation
5 Guides authored
Texas Tech, Team 2-2, Johansen Fall 2025 Member of Texas Tech, Team 2-2, Johansen Fall 2025
TTU-JOHANSEN-F25S2G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 55
All Time: 240
