Alcatel Go Flip 4 Motherboard Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
60
All Time:
322
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Is your Alcatel flip phone often freezing, working really slow, or randomly reseting itself?This guide provides a replacement guide for the motherboard on an Alcatel Go Flip phone 4.
Before replacing the motherboard, check out our troubleshooting page and come back to this replacement guide if you are still having issues.
Before beginning this repair, make sure to power off your phone and have it unplugged from the charger.
Tools
    1. Alcatel Go Flip 4 Motherboard Replacement, Battery: step 1, image 1 of 3 Alcatel Go Flip 4 Motherboard Replacement, Battery: step 1, image 2 of 3 Alcatel Go Flip 4 Motherboard Replacement, Battery: step 1, image 3 of 3
      • Insert a spudger into the notch on the back cover and gently pry upward until you hear a soft click, indicating the back has begun to separate.
      • Continue prying around the edges until the cover is fully removed.
      Ask FixBot
    2. Alcatel Go Flip 4 Motherboard Replacement: step 2, image 1 of 3 Alcatel Go Flip 4 Motherboard Replacement: step 2, image 2 of 3 Alcatel Go Flip 4 Motherboard Replacement: step 2, image 3 of 3
      • Insert a spudger into the midframe cutout and pry up to release the battery.
      • Remove the battery.
      Ask FixBot
    1. Alcatel Go Flip 4 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Alcatel Go Flip 4 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Alcatel Go Flip 4 Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Use a JIS #00 screwdriver to remove all nine 4.4 mm screws that secure the midframe.
      Ask FixBot
    2. Alcatel Go Flip 4 Motherboard Replacement: step 4, image 1 of 2 Alcatel Go Flip 4 Motherboard Replacement: step 4, image 2 of 2
      • Run the spudger under the midframe to pry it away from the rest of the phone.
      • Be very careful when removing the midframe as too much strain can cause it to snap.
      • Set the midframe aside.
      Ask FixBot
    3. Alcatel Go Flip 4 Motherboard Replacement: step 5, image 1 of 2 Alcatel Go Flip 4 Motherboard Replacement: step 5, image 2 of 2
      • Disconnect the ray bone connection.
      Ask FixBot
    4. Alcatel Go Flip 4 Motherboard Replacement: step 6, image 1 of 2 Alcatel Go Flip 4 Motherboard Replacement: step 6, image 2 of 2
      • Lift the silicon charging port cover.
      Ask FixBot
    5. Alcatel Go Flip 4 Motherboard Replacement: step 7, image 1 of 2 Alcatel Go Flip 4 Motherboard Replacement: step 7, image 2 of 2
      • Pry up the motherboard with the spudger.
      • Run the spudger along the perimeter of the motherboard.
      • Remove the motherboard from the phone.
      Ask FixBot
Dulcemaria Ramirez
641 Reputation
5 Guides authored
Texas Tech, Team 2-2, Johansen Fall 2025 Member of Texas Tech, Team 2-2, Johansen Fall 2025
TTU-JOHANSEN-F25S2G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 60
All Time: 322
