Tools
Spudger4.9
Introduction
Go to step 1 ↓Use this guide to replace the keypad to the Alcatel Go Flip 4.
A worn out, unresponsive, or stuck keypad can prevent you from navigating apps, making calls or writing texts.
Before replacing the keypad, rule out any other fixes by visiting our troubleshooting page first.
Before beginning this repair, make sure to power off your phone and have it unplugged from the charger. Take your time disassembling, as the plastic clips can be fragile.
Insert a spudger into the notch on the back cover and gently pry upward until you hear a soft click, indicating the back has begun to separate.
Continue prying around the edges until the cover is fully removed.
Use a JIS #00 screwdriver to remove all nine 4.4 mm screws that secure the midframe.
