Up to 20% off select tools
Alcatel Go Flip 3 Keypad Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
63
All Time:
302
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 9 - 15 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • iFixit Opening Tool
    4.8
    Optional
  • Spudger
    4.9
Introduction
Go to step 1 ↓
In order to replace the number pad on the Alcatel Go Flip 3 you need to follow the steps from our "motherboard replacement" guide.
    1. Alcatel Go Flip 3 Keypad Replacement, Battery: step 1, image 1 of 1
      • Place a fingernail or opening tool into the notch on the back panel of the phone.
      • Pry upwards to remove the back panel.
      Ask FixBot
    2. Alcatel Go Flip 3 Keypad Replacement: step 2, image 1 of 1
      • Remove the battery by lifting it up from the small indent.
      Ask FixBot
    1. Alcatel Go Flip 3 Keypad Replacement, Motherboard: step 3, image 1 of 1
      • Remove the nine 1 mm screws from the midframe using a Phillips #00 screwdriver.
      Ask FixBot
    2. Alcatel Go Flip 3 Keypad Replacement: step 4, image 1 of 2 Alcatel Go Flip 3 Keypad Replacement: step 4, image 2 of 2
      • Use a spudger to pry the midframe away from the phone.
      Ask FixBot
    3. Alcatel Go Flip 3 Keypad Replacement: step 5, image 1 of 2 Alcatel Go Flip 3 Keypad Replacement: step 5, image 2 of 2
      • Use a spudger to disconnect the video cable from the motherboard.
      • Make sure not to damage the video cable when disconnecting it from the motherboard. Hold it up correctly.
      Ask FixBot
    4. Alcatel Go Flip 3 Keypad Replacement: step 6, image 1 of 2 Alcatel Go Flip 3 Keypad Replacement: step 6, image 2 of 2
      • Use a spudger to pry the motherboard out of the phone.
      Ask FixBot
    1. Alcatel Go Flip 3 Keypad Replacement, Keypad: step 7, image 1 of 1
      • Grab one corner of the number pad and lift up to remove it from the phone.
      Ask FixBot
Author
with
Gustavo Cornier
375 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 63
All Time: 302
