Alcatel Go Flip 3 Charging Port Replacement
    1. Alcatel Go Flip 3 Charging Port Replacement, Battery: step 1, image 1 of 1
      • Place a fingernail or opening tool into the notch on the back panel of the phone.
      • Pry upwards to remove the back panel.
      Ask FixBot
    2. Alcatel Go Flip 3 Charging Port Replacement: step 2, image 1 of 1
      • Remove the battery by lifting it up from the small indent.
      Ask FixBot
    1. Alcatel Go Flip 3 Charging Port Replacement, Motherboard: step 3, image 1 of 1
      • Remove the nine 1 mm screws from the midframe using a Phillips #00 screwdriver.
      Ask FixBot
    2. Alcatel Go Flip 3 Charging Port Replacement: step 4, image 1 of 2 Alcatel Go Flip 3 Charging Port Replacement: step 4, image 2 of 2
      • Use a spudger to pry the midframe away from the phone.
      Ask FixBot
    3. Alcatel Go Flip 3 Charging Port Replacement: step 5, image 1 of 2 Alcatel Go Flip 3 Charging Port Replacement: step 5, image 2 of 2
      • Use a spudger to disconnect the video cable from the motherboard.
      • Make sure not to damage the video cable when disconnecting it from the motherboard. Hold it up correctly.
      Ask FixBot
    4. Alcatel Go Flip 3 Charging Port Replacement: step 6, image 1 of 2 Alcatel Go Flip 3 Charging Port Replacement: step 6, image 2 of 2
      • Use a spudger to pry the motherboard out of the phone.
      Ask FixBot
    1. Alcatel Go Flip 3 Charging Port Replacement, Charging Port: step 7, image 1 of 1
      • Desolder the charging port from the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 64
All Time: 270
