Alcatel 1B 2020 Screen Replacement
    1. Alcatel 1B 2020 Screen Replacement, Battery: step 1, image 1 of 3 Alcatel 1B 2020 Screen Replacement, Battery: step 1, image 2 of 3 Alcatel 1B 2020 Screen Replacement, Battery: step 1, image 3 of 3
      • For your safety, unplug all peripherals, discharge the battery below 25%, and power down your device before beginning disassembly.
      • Insert the opening tool into the seam between the back plastic case and the front screen.
      • Slide it around the edge of the phone to release the clips holding them together.
      • Remove the bottom case by hand.
      Ask FixBot
    2. Alcatel 1B 2020 Screen Replacement: step 2, image 1 of 3 Alcatel 1B 2020 Screen Replacement: step 2, image 2 of 3 Alcatel 1B 2020 Screen Replacement: step 2, image 3 of 3
      • Place the pry tool between the bottom of the battery and the bracket.
      • Lift the battery using the pry tool to remove it.
      Ask FixBot
    1. Alcatel 1B 2020 Screen Replacement, Rear Camera: step 3, image 1 of 3 Alcatel 1B 2020 Screen Replacement, Rear Camera: step 3, image 2 of 3 Alcatel 1B 2020 Screen Replacement, Rear Camera: step 3, image 3 of 3
      • Use a Phillips #000 screwdriver to remove sixteen 3.0 mm screws that secure the black plastic bracket.
      Ask FixBot
    2. Alcatel 1B 2020 Screen Replacement: step 4, image 1 of 3 Alcatel 1B 2020 Screen Replacement: step 4, image 2 of 3 Alcatel 1B 2020 Screen Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to pry the midframe from the bottom case.
      • Slide the end of the opening tool around the perimeter of the device to release the clips holding the midframe and bottom case together.
      • Be careful, the motherboard is located right beneath the midframe.
      • Remove the midframe from the phone.
      Ask FixBot
    3. Alcatel 1B 2020 Screen Replacement: step 5, image 1 of 3 Alcatel 1B 2020 Screen Replacement: step 5, image 2 of 3 Alcatel 1B 2020 Screen Replacement: step 5, image 3 of 3
      • Place a spudger or an opening tool under the camera press connector edge and pry straight up to disconnect it.
      • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
      • Use the tweezers to pull the rear camera out.
      Ask FixBot
    1. Alcatel 1B 2020 Screen Replacement, Motherboard: step 6, image 1 of 2 Alcatel 1B 2020 Screen Replacement, Motherboard: step 6, image 2 of 2
      • Insert a spudger or opening tool under the edge of the front camera cable connector and pry straight up to disconnect it.
      • Disconnect the other two press connectors near the red part of the motherboard.
      Ask FixBot
    2. Alcatel 1B 2020 Screen Replacement: step 7, image 1 of 3 Alcatel 1B 2020 Screen Replacement: step 7, image 2 of 3 Alcatel 1B 2020 Screen Replacement: step 7, image 3 of 3
      • Use tweezers to remove the motherboard from the phone.
      Ask FixBot
    1. Alcatel 1B 2020 Screen Replacement, Front Camera: step 8, image 1 of 3 Alcatel 1B 2020 Screen Replacement, Front Camera: step 8, image 2 of 3 Alcatel 1B 2020 Screen Replacement, Front Camera: step 8, image 3 of 3
      • Place the motherboard to the side.
      • The front camera ribbon connector was already removed in the previous step.
      • Use tweezers to pull the front-facing camera from the smartphone.
      Ask FixBot
    1. Alcatel 1B 2020 Screen Replacement, Screen: step 9, image 1 of 3 Alcatel 1B 2020 Screen Replacement, Screen: step 9, image 2 of 3 Alcatel 1B 2020 Screen Replacement, Screen: step 9, image 3 of 3
      • Flip your Alcatel 1B 2020 face up so the screen is facing you.
      • Slide the edge of the Jimmy between the case and the screen to pry it from the phone.
      • Insert opening picks under the screen as you work around the edge with the Jimmy to keep the adhesive from reattaching.
      Ask FixBot
    2. Alcatel 1B 2020 Screen Replacement: step 10, image 1 of 3 Alcatel 1B 2020 Screen Replacement: step 10, image 2 of 3 Alcatel 1B 2020 Screen Replacement: step 10, image 3 of 3
      • The screen will eventually lift with enough prying.
      • Flip the device over.
      • Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
      • Carefully slide the ribbon cable out from the opening at the edge of the frame.
      Ask FixBot
    3. Alcatel 1B 2020 Screen Replacement: step 11, image 1 of 3 Alcatel 1B 2020 Screen Replacement: step 11, image 2 of 3 Alcatel 1B 2020 Screen Replacement: step 11, image 3 of 3
      • Flip the device back over.
      • The LCD screen is very fragile. Be careful when prying and handling it.
      • The ribbon connector for the LCD screen was disconnected in the previous step, so the screen will pop up using the Jimmy.
      • Slide the Jimmy between the LCD and the digitizer to separate the two components.
      • Lift the LCD screen out with tweezers or your hands.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 18
All Time: 106
