Alcatel 1B 2020 Battery Replacement
    1. Alcatel 1B 2020 Battery Replacement, Battery: step 1, image 1 of 3 Alcatel 1B 2020 Battery Replacement, Battery: step 1, image 2 of 3 Alcatel 1B 2020 Battery Replacement, Battery: step 1, image 3 of 3
      • For your safety, unplug all peripherals, discharge the battery below 25%, and power down your device before beginning disassembly.
      • Insert the opening tool into the seam between the back plastic case and the front screen.
      • Slide it around the edge of the phone to release the clips holding them together.
      • Remove the bottom case by hand.
      Ask FixBot
    2. Alcatel 1B 2020 Battery Replacement: step 2, image 1 of 3 Alcatel 1B 2020 Battery Replacement: step 2, image 2 of 3 Alcatel 1B 2020 Battery Replacement: step 2, image 3 of 3
      • Place the pry tool between the bottom of the battery and the bracket.
      • Lift the battery using the pry tool to remove it.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 34
All Time: 202
