Up to 20% off select tools
Alan 48 Excel: Reception problems? No problem!
Views: 2.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
127
All Time:
2,355
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
If your Alan 48 Excel has poor reception or no reception at all, you should check the Q104 transistor receiver section and replace it if necessary.
      • First of all: Power off! Switch it off and unplug the device.
      • Then grab your screwdriver and undo the screws on the housing.
      • Carefully lift off the housing and put it to one side.
      Ask FixBot
      • Check all cables and connections. Are they properly seated?
      • Especially important: Check the connections to the antenna and the loudspeaker.
      Ask FixBot
      • Time for some contact spray and brushes! Spray the connections thoroughly.
      • Wait a few minutes, then wipe away the residue with a clean cloth.
      Ask FixBot
    1. Alan 48 Excel: Reception problems? No problem!, Check the transistor “Q104 (KTK 161)”: step 4, image 1 of 1
      • Find the transistor “Q104 (KTK 161)” on the circuit board. Here it is:
      • Take your multimeter and check the transistor. If it is defective, it must be replaced.
      Ask FixBot
    2. Alan 48 Excel: Reception problems? No problem!, Replace transistor “Q104 (KTK 161)”: step 5, image 1 of 1
      • In order to replace the transistor, carefully desolder the connections. This is where you need to start:
      • Insert the new transistor and solder it in place.
      • Check the connections with the multimeter to make sure that everything is properly working.
      Ask FixBot
      • Put the housing back on and tighten the screws.
      • Plug in the plug, switch on the device.
      • Test whether the reception is now better.
      Ask FixBot
That's it! With these steps, your Alan 48 Excel should have top reception again. If not, a major repair may be necessary.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Ingo Bünnemeyer
248 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 127
All Time: 2,355
