Up to 20% off select tools
Akko MOD 007 v2 Keyboard Switch Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
114
All Time:
2,778
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your Akko MOD 007 v2 has a switch not working correctly, you will need to replace the keyboard switch to restore its functionality. These keyboard switches wear down over time, rendering them inoperable as they no longer register. Before replacing the switch, inspect the keyboard to confirm that it is the switch and not the PCB malfunctioning.
In this guide, you'll learn how to replace the keyboard switch through on your Akko MOD 007 v2. It has two features that make it simple. The keyboard is hot-swappable, which allows you to replace the switch without soldering. In addition, when buying a replacement keyboard switch, the Akko MOD 007 v2 is compatible with both PCB-mounted (5-pin) and, Plate-mounted (3-pin) switches.
Replacing more than one switch can be reproduced by repeating these instructions.
    1. Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: step 1, image 1 of 2 Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: step 1, image 2 of 2
      • Unplug the USB-C cable.
      Ask FixBot
    2. Akko MOD 007 v2 Keyboard Switch Replacement: step 2, image 1 of 2 Akko MOD 007 v2 Keyboard Switch Replacement: step 2, image 2 of 2
      • Flip the keyboard over so the backside is facing up.
      • Remove the three longer 20.2 mm screws using the T5 Torx screwdriver.
      • Remove the three 8 mm screws using the T5 Torx screwdriver.
      Ask FixBot
    3. Akko MOD 007 v2 Keyboard Switch Replacement: step 3, image 1 of 2 Akko MOD 007 v2 Keyboard Switch Replacement: step 3, image 2 of 2
      • Pull the front and back case apart.
      • If your keyboard is dirty, you’ll want to clean it before continuing. Use compressed air or a brush.
      Ask FixBot
    4. Akko MOD 007 v2 Keyboard Switch Replacement: step 4, image 1 of 2 Akko MOD 007 v2 Keyboard Switch Replacement: step 4, image 2 of 2
      • Insert the keycap puller horizontally on the keycap and pull up.
      • Excessive force may break the tool or keycaps so don't yank the keycap up.
      Ask FixBot
    5. Akko MOD 007 v2 Keyboard Switch Replacement: step 5, image 1 of 2 Akko MOD 007 v2 Keyboard Switch Replacement: step 5, image 2 of 2
      • Insert the switch puller vertically in the switch tabs and gently pull up.
      Ask FixBot
    6. Akko MOD 007 v2 Keyboard Switch Replacement: step 6, image 1 of 3 Akko MOD 007 v2 Keyboard Switch Replacement: step 6, image 2 of 3 Akko MOD 007 v2 Keyboard Switch Replacement: step 6, image 3 of 3
      • Orientate the new switch to align the pins to the board's sockets.
      • Push the switch down into the sockets.
      • Make sure the pins are aligned to sockets, as misalignment will cause the switch to be faulty.
      Ask FixBot
Test the switch by opening a keyboard tester website, like 'keyboardtester.com,' and press the key to see if it activates.
Author
with
Farhan
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 114
All Time: 2,778
