Akaso EK7000 4K Button Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
79
All Time:
3,264
Comments: 6
3 comments on steps, 3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a guide to replacing the up and down buttons on your Akaso EK7000. Required tools are: a metal spudger or any other instrument used to pry or separate, and a Phillips #000 screwdriver.
Tools
    1. Akaso EK7000 4K Button Replacement, Battery: step 1, image 1 of 2 Akaso EK7000 4K Button Replacement, Battery: step 1, image 2 of 2
      • Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
      Ask FixBot
    2. Akaso EK7000 4K Button Replacement: step 2, image 1 of 2 Akaso EK7000 4K Button Replacement: step 2, image 2 of 2
      • Locate the small plastic flap attached to the battery. Pull the battery out towards you.
      Ask FixBot
    1. Akaso EK7000 4K Button Replacement, Front Panel: step 3, image 1 of 2 Akaso EK7000 4K Button Replacement, Front Panel: step 3, image 2 of 2
      • Using the metal spudger, gently pry open the front panel from the exposed battery cartridge.
      Ask FixBot
    2. Akaso EK7000 4K Button Replacement: step 4, image 1 of 2 Akaso EK7000 4K Button Replacement: step 4, image 2 of 2
      • Remove the rest of front panel with your fingers or with assistance from the spudger.
      Ask FixBot
    1. Akaso EK7000 4K Button Replacement, Button: step 5, image 1 of 2 Akaso EK7000 4K Button Replacement, Button: step 5, image 2 of 2
      • Using a Phillips #000 screwdriver, remove the four screws securing the cover plate.
      Ask FixBot
    2. Akaso EK7000 4K Button Replacement: step 6, image 1 of 2 Akaso EK7000 4K Button Replacement: step 6, image 2 of 2
      • Using your thumb or a spudger, gently push up from inside the battery cartridge.
      • Gently lift the cover plate until you can see into the inside of the camera. The cover will not completely come off, so be careful not to damage any of the inner wiring.
      Ask FixBot
    3. Akaso EK7000 4K Button Replacement: step 7, image 1 of 2 Akaso EK7000 4K Button Replacement: step 7, image 2 of 2
      • Using the metal spudger, push down on the up and down button as shown in the picture. Dislodge the button and it should fall to the bottom of the camera.
      Ask FixBot
    4. Akaso EK7000 4K Button Replacement: step 8, image 1 of 2 Akaso EK7000 4K Button Replacement: step 8, image 2 of 2
      • Again, using the metal spudger, gently pull out the button from within the camera.
      Ask FixBot
3 other people completed this guide.
Annie Sun
457 Reputation
3 Guides authored
UC Davis, Team S20-G2, Lore Winter 2019 Member of UC Davis, Team S20-G2, Lore Winter 2019
UCD-LORE-W19S20G2
3 Members
48 Guides authored
3 Guide Comments
Annie, where do I get the replacemnet bottons for the Akaso 7000 pro?
ecab110544 - Reply Share
I need a replacement top button. Plastic got messed up but was able to still press the metallic part. But didn't realize it wasn't secure and it fell off at some point. Can start recording by shorting across contacts but looking for a fix.
Mark - Reply Share
Who is going to answer above questions?
luis - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 79
All Time: 3,264
