Up to 20% off select tools
Akai MPK25 LCD Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
100
All Time:
2,843
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a screen that is scratched, cracked, or broken.
    1. Akai MPK25 LCD Replacement, Face Plate: step 1, image 1 of 1
      • Remove all the selector knob covers by pulling them off.
      Ask FixBot
    2. Akai MPK25 LCD Replacement: step 2, image 1 of 1
      • Using needle nose pliers, remove the washers from the four corner selector knobs.
      Ask FixBot
    3. Akai MPK25 LCD Replacement: step 3, image 1 of 1
      • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
      Ask FixBot
    4. Akai MPK25 LCD Replacement: step 4, image 1 of 3 Akai MPK25 LCD Replacement: step 4, image 2 of 3 Akai MPK25 LCD Replacement: step 4, image 3 of 3
      • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
      • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
      Ask FixBot
    5. Akai MPK25 LCD Replacement: step 5, image 1 of 3 Akai MPK25 LCD Replacement: step 5, image 2 of 3 Akai MPK25 LCD Replacement: step 5, image 3 of 3
      • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
      • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
      Ask FixBot
    1. Akai MPK25 LCD Replacement, LCD: step 6, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the four 8.9 mm screws.
      Ask FixBot
    2. Akai MPK25 LCD Replacement: step 7, image 1 of 1
      • Using a Phillips #2 screwdriver, remove the one 9.8mm screw holding down the ground wire.
      Ask FixBot
    3. Akai MPK25 LCD Replacement: step 8, image 1 of 2 Akai MPK25 LCD Replacement: step 8, image 2 of 2
      • Using two plastic opening tools, slide the black locking mechanism on the ZIF connector towards you. This will remove the ribbon cable connecting the motherboard to the screen.
      Ask FixBot
    4. Akai MPK25 LCD Replacement: step 9, image 1 of 1
      • Lift the screen from either side, removing it from the board.
      Ask FixBot
To reassemble the display, follow these instructions in reverse order.
3 other people completed this guide.
Author
with
Will Saba
412 Reputation
2 Guides authored
Cal Poly, Team 20-6, Maness Winter 2013 Member of Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 Members
72 Guides authored
1 Guide Comment
Where can I find a new ribbon?
Wise Professor - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 100
All Time: 2,843
