Up to 20% off select tools
Akai MPK25 Keys Replacement
Views: 12K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
132
All Time:
12,450
Comments: 2
2 comments on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide if any of the keys are broken, chipped, or stuck.
    1. Akai MPK25 Keys Replacement, Face Plate: step 1, image 1 of 1
      • Remove all the selector knob covers by pulling them off.
      Ask FixBot
    2. Akai MPK25 Keys Replacement: step 2, image 1 of 1
      • Using needle nose pliers, remove the washers from the four corner selector knobs.
      Ask FixBot
    3. Akai MPK25 Keys Replacement: step 3, image 1 of 1
      • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
      Ask FixBot
    4. Akai MPK25 Keys Replacement: step 4, image 1 of 3 Akai MPK25 Keys Replacement: step 4, image 2 of 3 Akai MPK25 Keys Replacement: step 4, image 3 of 3
      • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
      • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
      Ask FixBot
    5. Akai MPK25 Keys Replacement: step 5, image 1 of 3 Akai MPK25 Keys Replacement: step 5, image 2 of 3 Akai MPK25 Keys Replacement: step 5, image 3 of 3
      • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
      • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
      Ask FixBot
    1. Akai MPK25 Keys Replacement, Keys: step 6, image 1 of 2 Akai MPK25 Keys Replacement, Keys: step 6, image 2 of 2
      • Using needle nose pliers, grip the top of the spring coil, that is holding down the key, and gently lift the spring away from the key.
      Ask FixBot
    2. Akai MPK25 Keys Replacement: step 7, image 1 of 1
      • Lift the key from the front of the keyboard towards the back in order to remove it completely.
      Ask FixBot
To reassemble the keyboard and close up the case, follow these instructions in reverse order.
7 other people completed this guide.
Author
with
Will Saba
412 Reputation
2 Guides authored
Cal Poly, Team 20-6, Maness Winter 2013 Member of Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 132
All Time: 12,450
