Airpress LM 50-350 Oil Replacement
    1. Airpress LM 50-350 Oil Replacement, prepare draining oil: step 1, image 1 of 1
      • To ease the draining process, run the compressor for a few minutes and warm up the oil a bit.
      • Make sure to unplug the compressor at this point.
      • Unscrew the filler cap to allow air into the reservoir.
      Ask FixBot
    2. Airpress LM 50-350 Oil Replacement, drain the oil: step 2, image 1 of 2 Airpress LM 50-350 Oil Replacement, drain the oil: step 2, image 2 of 2
      • Using the 5mm hex key, unscrew the drainage plug.
      • With the plug removed, let the reservoir drain until no more oil comes out.
      Ask FixBot
    3. Airpress LM 50-350 Oil Replacement, add oil: step 3, image 1 of 2 Airpress LM 50-350 Oil Replacement, add oil: step 3, image 2 of 2
      • Screw the drainage plug back on.
      • Add the new oil through the filler hole.
      • Make sure the oil level on the indicator is between the lines.
      Ask FixBot
Finish Line
7 other people completed this guide.
knipwim
15,516 Reputation
44 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 55
All Time: 5,804
