Airox Legendair Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
58
All Time:
813
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Medical Equipment Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Introduction
Go to step 1 ↓
When the battery warning alarm cannot be properly reset from the simple troubleshooting and the voltage from the battery is severely low, it may be necessary to replace the battery. This repair guide will aid the user through the process of replacing the battery in the ventilator.
The repair guide information is mentioned in following sections of the user repair manual as well:
· Chapter 2 – 2.1.1 Cleaning the Device
· Chapter 2 – 2.4.1 Opening and Closing
· Chapter 5 – 5.1.1 Removal/Installation of the Battery
    1. Airox Legendair Battery Replacement, How to Properly Clean the Airox Legendair: step 1, image 1 of 1
      • First, switch off the device.
      Ask FixBot
      • Place the device in a clean and open environment.
      Ask FixBot
    2. Airox Legendair Battery Replacement: step 3, image 1 of 1
      • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
      Ask FixBot
    3. Airox Legendair Battery Replacement: step 4, image 1 of 1
      • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
      • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
      Ask FixBot
      • Use a gentle air blast to clear away any remaining liquid from ventilator.
      Ask FixBot
    1. Airox Legendair Battery Replacement, Battery: step 6, image 1 of 1
      • Make sure to turn off the ventilator before starting the repair.
      • Before you start the battery replacement process, make sure that the device has been placed in a clean and open environment.
      Ask FixBot
    2. Airox Legendair Battery Replacement: step 7, image 1 of 1
      • Remove each attachment screw from the battery cover.
      Ask FixBot
    3. Airox Legendair Battery Replacement: step 8, image 1 of 1
      • Remove the battery cover carefully by holding the rails and pulling toward the rear of the device.
      Ask FixBot
    4. Airox Legendair Battery Replacement: step 9, image 1 of 1
      • Extract the current battery and replace it with the new battery.
      Ask FixBot
    5. Airox Legendair Battery Replacement: step 10, image 1 of 1
      • Confirm that all elements line up together. Then, reattach the battery cover with the attachment screws that were removed in Step 2.
      Ask FixBot
    6. Airox Legendair Battery Replacement: step 11, image 1 of 1
      • Switch the device to "Set Up Mode" by pressing the On/Off switch.
      • Hold the menu key until the menu options appear on the screen.
      • Select the "MAINTENANCE" option with cursor.
      • Select "Voltage control" and verify that the voltage of the battery is 28.5±1V.
      Ask FixBot
Perform the final inspection procedures by confirming that every screw is secure before putting back into service.
Caleb Erlenborn
174 Reputation
1 Guide authored
Cal Poly, Team S7-G15, Paton Spring 2020 Member of Cal Poly, Team S7-G15, Paton Spring 2020
CPSU-PATON-S20S7G15
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 58
All Time: 813
