Up to 20% off select tools
AirCard 770S SIM Card Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
65
All Time:
2,532
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide is designed to help you replace your SIM Card in the device. In order to replace your SIM Card you must have a new SIM Card or are simply learning how to properly insert a SIM Card. Make sure your SIM Card is the correct size to fit into the area in your device.
    1. AirCard 770S SIM Card Replacement, SIM Card: step 1, image 1 of 1
      • Hold the device with the charging port side facing up.
      Ask FixBot
    2. AirCard 770S SIM Card Replacement: step 2, image 1 of 1
      • Look to the left of the charging port and peel back the SIM Card slot in order to open it.
      Ask FixBot
    3. AirCard 770S SIM Card Replacement: step 3, image 1 of 1
      • If there is already a SIM Card in the slot, use your finger to press in the SIM Card so that it will pop out slightly. If it does not pop out the first time, press it in again.
      • The SIM Card is not shown in picture. The red circle is where the SIM Card would be located.
      Ask FixBot
    4. AirCard 770S SIM Card Replacement: step 4, image 1 of 1
      • Use your fingers and carefully pull out the old SIM Card.
      • The SIM Card is not included in picture. The orange circle is where SIM Card would be located on the device.
      • When reassembling the device, make sure to press in the new SIM Card all the way so that the port can be closed and you can then power on the device.
      Ask FixBot
Author
with
Caitlin Little
437 Reputation
3 Guides authored
Marist, Team S1-G2, Chaterdon Fall 2018 Member of Marist, Team S1-G2, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 65
All Time: 2,532
