Up to 20% off select tools
AirCard 770S Back Case Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
58
All Time:
756
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
If the back case of your device is broken or keeps falling off and does not stay on, you will learn how to replace the backing in order to prevent any complications in the device.
    1. AirCard 770S Back Case Replacement, Back Case: step 1, image 1 of 1
      • Hold the device with an open corner available and facing you.
      Ask FixBot
    2. AirCard 770S Back Case Replacement: step 2, image 1 of 1
      • Using your finger, pry open any of the four corners of the back case of your AirCard 770S, until you see the back case disconnect from the device.
      Ask FixBot
    3. AirCard 770S Back Case Replacement: step 3, image 1 of 1
      • Lift open the back case and remove it from the device.
      • In order to put a new back case on, make sure to align the white nobs found on the back cover, so that you do not force the case on and cause any damage to the device.
      Ask FixBot
Author
with
Caitlin Little
437 Reputation
3 Guides authored
Marist, Team S1-G2, Chaterdon Fall 2018 Member of Marist, Team S1-G2, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 58
All Time: 756
