Air Hog Smash Bots Motor Replacement
    1. Air Hog Smash Bots Motor Replacement, Batteries: step 1, image 1 of 1
      • Using the Phillips #0 screwdriver to remove the 8 mm screw.
      Ask FixBot
    2. Air Hog Smash Bots Motor Replacement: step 2, image 1 of 1
      • Lift and slide the batter cover away from the tab holding it in place at the bottom.
      Ask FixBot
    3. Air Hog Smash Bots Motor Replacement: step 3, image 1 of 1
      • Remove the 3 AAA batteries.
      Ask FixBot
    1. Air Hog Smash Bots Motor Replacement, External Casing: step 4, image 1 of 2 Air Hog Smash Bots Motor Replacement, External Casing: step 4, image 2 of 2
      • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
      Ask FixBot
    2. Air Hog Smash Bots Motor Replacement: step 5, image 1 of 2 Air Hog Smash Bots Motor Replacement: step 5, image 2 of 2
      • Remove the upper armor of the Smash Bot.
      Ask FixBot
    3. Air Hog Smash Bots Motor Replacement: step 6, image 1 of 1
      • Hold the upper body and slide out the bottom half of the Smash Bot.
      • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
      Ask FixBot
    4. Air Hog Smash Bots Motor Replacement: step 7, image 1 of 1
      • Peel back the four decal stickers that hold the front and back of the bot together.
      Ask FixBot
    5. Air Hog Smash Bots Motor Replacement: step 8, image 1 of 2 Air Hog Smash Bots Motor Replacement: step 8, image 2 of 2
      • Use the plastic opening tool to pry the front and back of the lower body apart.
      • Carefully remove the back of the bot from the front.
      Ask FixBot
    1. Air Hog Smash Bots Motor Replacement, Motor: step 9, image 1 of 2 Air Hog Smash Bots Motor Replacement, Motor: step 9, image 2 of 2
      • Using the Phillips #0 screwdriver, remove six 4.75mm screws.
      Ask FixBot
    2. Air Hog Smash Bots Motor Replacement: step 10, image 1 of 1
      • Use the soldering iron to remove the blue and green wire from the motor casing. Directions on how to solder can be found here.
      Ask FixBot
Brittany Frecker
542 Reputation
4 Guides authored
IUPUI, Team 1-1, Baechle Spring 2016 Member of IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Members
28 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 448
