Up to 20% off select tools
Air Filter Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
137
All Time:
975
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This short simple guide will show you how to replace the air filter in a filter grill that is commonly used for residential central air systems
    1. Air Filter Replacement, Filter: step 1, image 1 of 1
      • Locate air filter grille
      • This is usually found near the thermostat
      • Some systems contain multiple filters
      • Not all duct systems have a filter grill. Some are filtered at the air handling appliance
      Ask FixBot
    2. Air Filter Replacement, Open the grill: step 2, image 1 of 2 Air Filter Replacement, Open the grill: step 2, image 2 of 2
      • Pull out both latches so that they are perpendicular to the wall
      • Pull grill open from top center
      Ask FixBot
    3. Air Filter Replacement, Remove used filter: step 3, image 1 of 1
      • Remove the dirty filter
      Ask FixBot
      • If you aren't sure if the filter is ready to be changed just remember this is what cleans the air you are breathing.
      • Never wash or reuse a disposable filter
      • Pleated filters remove more dirt from the air than fiberglass filters. But their density restricts the air flow more. This can create problems in some systems. Experiment with both and see which is best for you and your system.
      • Filters should be checked every 30 days on residential applications and every 15 days on commercial applications.
      Ask FixBot
Author
with
gsdfert34f2efse34
43 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 137
All Time: 975
