Aiptek Pocket DVII 1.3M LCD Memory Ejecting Assembly Replacement
  1. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: step 1, image 1 of 3 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: step 1, image 2 of 3 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: step 1, image 3 of 3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 2, image 1 of 1
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 3, image 1 of 1
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 4, image 1 of 2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 4, image 2 of 2
    • Remove the sticky black dot.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 5, image 1 of 2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 5, image 2 of 2
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 6, image 1 of 1
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 7, image 1 of 1
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 8, image 1 of 1
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 9, image 1 of 1
    • Remove the four screws from the motherboard.
  10. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 10, image 1 of 1
    • Take out the motherboard while disconnecting the flip screen's cable from underneath.
  11. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 11, image 1 of 1
    • Remove the side cover.
    • Flip the device and locate the ejecting assembly.
  12. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 12, image 1 of 1
    • Remove the grey button.
  13. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 13, image 1 of 1
    • Push the metal arm the button was on all the way up.
  14. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 14, image 1 of 2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: step 14, image 2 of 2
    • Pop the main metal arm out of the other metal arm's socket.
    • Position the arm vertically like in the first picture. The arm should come off easily.
    • Replace the ejecting arm.
Gyozo Aba Hivatal
561 Reputation
5 Guides authored
USF Tampa, Team 6-4, Brown Winter 2015 Member of USF Tampa, Team 6-4, Brown Winter 2015
USFT-BROWN-W15S6G4
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 22
All Time: 266
