Aiptek DZO-V58N Image Sensor Replacement
    1. Aiptek DZO-V58N Image Sensor Replacement, Battery: step 1, image 1 of 1
      • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
      • Slide the battery compartment cover down off of the camera body.
      Ask FixBot
    2. Aiptek DZO-V58N Image Sensor Replacement: step 2, image 1 of 1
      • Pry up the battery from the bottom using a finger and remove the batter from the case.
      Ask FixBot
    1. Aiptek DZO-V58N Image Sensor Replacement, Lens Protector: step 3, image 1 of 1
      • Remove the lanyard by pulling the grey lace through the black string loop.
      • Pull black string loop through the silver bracket.
      Ask FixBot
    2. Aiptek DZO-V58N Image Sensor Replacement: step 4, image 1 of 1
      • Use a plastic opening tool to pry off the black control cover.
      • The face plates are glued, so use force to pry the face plates from the camera body.
      Ask FixBot
    3. Aiptek DZO-V58N Image Sensor Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to pry off the ridged back face plate and the black button.
      • The button is loose and should come off with little or no effort.
      Ask FixBot
    4. Aiptek DZO-V58N Image Sensor Replacement: step 6, image 1 of 1
      • Use a plastic opening tool to pry off the silver face plate.
      Ask FixBot
    5. Aiptek DZO-V58N Image Sensor Replacement: step 7, image 1 of 3 Aiptek DZO-V58N Image Sensor Replacement: step 7, image 2 of 3 Aiptek DZO-V58N Image Sensor Replacement: step 7, image 3 of 3
      • Open the USB cover to expose the small machine screw.
      • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
      • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
      Ask FixBot
    6. Aiptek DZO-V58N Image Sensor Replacement: step 8, image 1 of 1
      • Pull off the side control panel.
      Ask FixBot
    7. Aiptek DZO-V58N Image Sensor Replacement: step 9, image 1 of 2 Aiptek DZO-V58N Image Sensor Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Flip open the screen by pulling the loose end of the screen away from the case.
      • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
      • Use the #00 Phillips Screwdriver to remove both screws.
      Ask FixBot
    8. Aiptek DZO-V58N Image Sensor Replacement: step 10, image 1 of 2 Aiptek DZO-V58N Image Sensor Replacement: step 10, image 2 of 2
      • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
      • Use tweezers to remove the silver plastic strap holder.
      • Use a plastic opening tool to pry off the lens protector.
      Ask FixBot
    1. Aiptek DZO-V58N Image Sensor Replacement, Lens: step 11, image 1 of 3 Aiptek DZO-V58N Image Sensor Replacement, Lens: step 11, image 2 of 3 Aiptek DZO-V58N Image Sensor Replacement, Lens: step 11, image 3 of 3
      • Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
      • Lift off the lens protector housing.
      • Pull apart the two halves of the camera body.
      • Do not pull the two halves apart too far because the wires may detach.
      Ask FixBot
    2. Aiptek DZO-V58N Image Sensor Replacement: step 12, image 1 of 1
      • Unscrew both black machine screws holding the lens in place with the #00 Phillips screwdriver.
      Ask FixBot
    3. Aiptek DZO-V58N Image Sensor Replacement: step 13, image 1 of 1
      • Carefully remove the compressed springs underneath each of the two screws that were removed in the previous step.
      • Be careful not to lose the springs. The springs are in compression and will launch from the camera if not held onto.
      Ask FixBot
    4. Aiptek DZO-V58N Image Sensor Replacement: step 14, image 1 of 1
      • Lift off the lens.
      Ask FixBot
    1. Aiptek DZO-V58N Image Sensor Replacement, Image Sensor: step 15, image 1 of 2 Aiptek DZO-V58N Image Sensor Replacement, Image Sensor: step 15, image 2 of 2
      • Use the #00 Phillips Screwdriver to unscrew the 3 circuit board screws.
      • Slightly separate circuit board from plastic case by lifting the circuit board straight out.
      Ask FixBot
    2. Aiptek DZO-V58N Image Sensor Replacement: step 16, image 1 of 2 Aiptek DZO-V58N Image Sensor Replacement: step 16, image 2 of 2
      • Unplug the image sensor from the circuit board.
      • Pull the image sensor straight out to avoid damage to the pin connectors.
      Ask FixBot
Zachary Yun
28 Reputation
5 Guides authored
Cal Poly, Team 5-5, Forte Spring 2012 Member of Cal Poly, Team 5-5, Forte Spring 2012
CPSU-FORTE-S12S5G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 1,166
