Afterglow Wireless PS3 Controller Vibration Motor Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
82
All Time:
1,755
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 50 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide shows the steps required to replace the vibration motors in a PS3 Wireless Afterglow Controller.
Tools
    1. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: step 1, image 1 of 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Back Cover: step 1, image 2 of 2
      • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
      • Lift up and remove the controller back plate.
      Ask FixBot
    1. Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: step 2, image 1 of 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement, Vibration Motor: step 2, image 2 of 2
      • Carefully remove the battery by lifting it straight up from its place.
      • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
      Ask FixBot
    2. Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 3, image 1 of 1
      • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
      Ask FixBot
    3. Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 4, image 1 of 3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 4, image 2 of 3 Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 4, image 3 of 3
      • Jiggle both joy stick control mini-motherboards out of their holding place.
      • Set aside the mini-motherboards so that the vibration motor wire connections are accessible.
      Ask FixBot
    4. Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 5, image 1 of 2 Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 5, image 2 of 2
      • Pull both vibration motors straight up from their holding place.
      Ask FixBot
    5. Afterglow Wireless PS3 Controller Vibration Motor Replacement: step 6, image 1 of 1
      • Use the soldering tool to heat the solder connecting the red and black vibration motor wires to the motherboard to detach the vibration motors.
      • Use this guide for further details on how to solder.
      Ask FixBot
Natalie Cox
207 Reputation
2 Guides authored
USF Tampa, Team S19-G5, Hoffman Spring 2017 Member of USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 82
All Time: 1,755
