Tools
Introduction
Go to step 1 ↓Replacing the trigger button requires the removal of the controller back plate and the careful pulling of the trigger from its housing.
Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
Lift up and remove the controller back plate.
With one hand, hold the controller down and with the other pull up on the lower clear plastic trigger housing to remove it.
4 other people completed this guide.
