Up to 20% off select tools
Afridev Tank Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
97
All Time:
957
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this guide to replace the casing of the Afridev pump, or to remove it for further repairs.
    1. Afridev Tank Replacement, Head: step 1, image 1 of 2 Afridev Tank Replacement, Head: step 1, image 2 of 2
      • Assemble the required tools, including the Afridev tool and crescent wrenches.
      Ask FixBot
    2. Afridev Tank Replacement: step 2, image 1 of 3 Afridev Tank Replacement: step 2, image 2 of 3 Afridev Tank Replacement: step 2, image 3 of 3
      • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
      Ask FixBot
    3. Afridev Tank Replacement: step 3, image 1 of 2 Afridev Tank Replacement: step 3, image 2 of 2
      • Loosen the bolt on front of the face plate with the Afridev tool.
      • Remove the plate from the pump by lifting it straight up.
      Ask FixBot
    1. Afridev Tank Replacement, Axle and Handle: step 4, image 1 of 3 Afridev Tank Replacement, Axle and Handle: step 4, image 2 of 3 Afridev Tank Replacement, Axle and Handle: step 4, image 3 of 3
      • Insert the T-handle into the top cylinder of the exposed pump rod.
      Ask FixBot
    2. Afridev Tank Replacement: step 5, image 1 of 2 Afridev Tank Replacement: step 5, image 2 of 2
      • Loosen the 2 bolts on either side of handle.
      • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
      Ask FixBot
    3. Afridev Tank Replacement: step 6, image 1 of 3 Afridev Tank Replacement: step 6, image 2 of 3 Afridev Tank Replacement: step 6, image 3 of 3
      • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
      Ask FixBot
    4. Afridev Tank Replacement: step 7, image 1 of 2 Afridev Tank Replacement: step 7, image 2 of 2
      • Lift the handle to a horizontal position.
      Ask FixBot
    5. Afridev Tank Replacement: step 8, image 1 of 3 Afridev Tank Replacement: step 8, image 2 of 3 Afridev Tank Replacement: step 8, image 3 of 3
      • While one person lifts up on the T-handle, remove the bolt and connection pieces.
      Ask FixBot
    6. Afridev Tank Replacement: step 9, image 1 of 3 Afridev Tank Replacement: step 9, image 2 of 3 Afridev Tank Replacement: step 9, image 3 of 3
      • Remove the bolt and connection pieces from the handle.
      • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
      Ask FixBot
    7. Afridev Tank Replacement: step 10, image 1 of 2 Afridev Tank Replacement: step 10, image 2 of 2
      • Remove the handle from the pump.
      • Be sure to set the handle in a sanitary place to prevent contamination.
      Ask FixBot
    1. Afridev Tank Replacement, Pump Rod: step 11, image 1 of 2 Afridev Tank Replacement, Pump Rod: step 11, image 2 of 2
      • Grab firmly on the T-handle and lift the pump rod straight up.
      • Expose the first connection of the pump rod, and support the portion below the connection.
      Ask FixBot
    2. Afridev Tank Replacement: step 12, image 1 of 2 Afridev Tank Replacement: step 12, image 2 of 2
      • While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
      Ask FixBot
    3. Afridev Tank Replacement: step 13, image 1 of 3 Afridev Tank Replacement: step 13, image 2 of 3 Afridev Tank Replacement: step 13, image 3 of 3
      • Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
      Ask FixBot
    4. Afridev Tank Replacement: step 14, image 1 of 3 Afridev Tank Replacement: step 14, image 2 of 3 Afridev Tank Replacement: step 14, image 3 of 3
      • Repeat steps 11-13 for the remaining sections of pump rod.
      • Be sure to set the pump rod segments above the ground to avoid contamination.
      Ask FixBot
    1. Afridev Tank Replacement, Tank: step 15, image 1 of 2 Afridev Tank Replacement, Tank: step 15, image 2 of 2
      • Place one wrench on the top side of the top base of the tank spout.
      • Place another wrench on the underside of the bolt in order to get more leverage.
      • Pull the top wrench to the right, and the bottom wrench to the left.
      Ask FixBot
    2. Afridev Tank Replacement: step 16, image 1 of 3 Afridev Tank Replacement: step 16, image 2 of 3 Afridev Tank Replacement: step 16, image 3 of 3
      • Remove the loosened bolt from the pump.
      • Repeat this procedure for the 3 remaining bolts.
      Ask FixBot
    3. Afridev Tank Replacement: step 17, image 1 of 2 Afridev Tank Replacement: step 17, image 2 of 2
      • Lift the tank straight up to remove it from the pump.
      • Be sure to place the tank in a sanitary place to prevent contamination.
      Ask FixBot
Author
with
Jake Devincenzi
119,666 Reputation
57 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 97
All Time: 957
