Afridev Axle and Handle Replacement
    1. Afridev Axle and Handle Replacement, Head: step 1, image 1 of 2 Afridev Axle and Handle Replacement, Head: step 1, image 2 of 2
      • Assemble the required tools, including the Afridev tool and crescent wrenches.
      Ask FixBot
    2. Afridev Axle and Handle Replacement: step 2, image 1 of 3 Afridev Axle and Handle Replacement: step 2, image 2 of 3 Afridev Axle and Handle Replacement: step 2, image 3 of 3
      • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
      Ask FixBot
    3. Afridev Axle and Handle Replacement: step 3, image 1 of 2 Afridev Axle and Handle Replacement: step 3, image 2 of 2
      • Loosen the bolt on front of the face plate with the Afridev tool.
      • Remove the plate from the pump by lifting it straight up.
      Ask FixBot
    1. Afridev Axle and Handle Replacement, Axle and Handle: step 4, image 1 of 3 Afridev Axle and Handle Replacement, Axle and Handle: step 4, image 2 of 3 Afridev Axle and Handle Replacement, Axle and Handle: step 4, image 3 of 3
      • Insert the T-handle into the top cylinder of the exposed pump rod.
      Ask FixBot
    2. Afridev Axle and Handle Replacement: step 5, image 1 of 2 Afridev Axle and Handle Replacement: step 5, image 2 of 2
      • Loosen the 2 bolts on either side of handle.
      • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
      Ask FixBot
    3. Afridev Axle and Handle Replacement: step 6, image 1 of 3 Afridev Axle and Handle Replacement: step 6, image 2 of 3 Afridev Axle and Handle Replacement: step 6, image 3 of 3
      • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
      Ask FixBot
    4. Afridev Axle and Handle Replacement: step 7, image 1 of 2 Afridev Axle and Handle Replacement: step 7, image 2 of 2
      • Lift the handle to a horizontal position.
      Ask FixBot
    5. Afridev Axle and Handle Replacement: step 8, image 1 of 3 Afridev Axle and Handle Replacement: step 8, image 2 of 3 Afridev Axle and Handle Replacement: step 8, image 3 of 3
      • While one person lifts up on the T-handle, remove the bolt and connection pieces.
      Ask FixBot
    6. Afridev Axle and Handle Replacement: step 9, image 1 of 3 Afridev Axle and Handle Replacement: step 9, image 2 of 3 Afridev Axle and Handle Replacement: step 9, image 3 of 3
      • Remove the bolt and connection pieces from the handle.
      • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
      Ask FixBot
    7. Afridev Axle and Handle Replacement: step 10, image 1 of 2 Afridev Axle and Handle Replacement: step 10, image 2 of 2
      • Remove the handle from the pump.
      • Be sure to set the handle in a sanitary place to prevent contamination.
      Ask FixBot
Jake Devincenzi
119,471 Reputation
57 Guides authored
2 Guide Comments
J'ai besoin de pompe
Sylvain Monga - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 21
All Time: 1,181
