Introduction
This guide walks you through replacing the air pump in an AeroGarden hydroponic system, including models such as the AeroGarden Harvest, Harvest Elite, Sprout, and other variants that use the same internal aeration design. In this repair, you will remove the original air pump and install a new unit to restore proper oxygenation within the grow deck. The air pump plays a critical role in circulating oxygen through the nutrient solution, preventing stagnation, supporting healthy root development, and maintaining overall plant vitality.
If your AeroGarden is experiencing issues such as reduced bubbling, no aeration, unusual humming or rattling, weak airflow, or plants showing signs of root rot or slowed growth, the air pump may be failing. For help diagnosing the issue, refer to the relevant sections of your manual under the Troubleshooting section.
Before beginning this repair, review all safety considerations. Always disconnect the AeroGarden from power before opening the base to avoid electrical hazards. Be cautious of water exposure near electronics, and ensure the bowl is emptied or removed to prevent spills. Use ESD‑safe tools when handling internal components, and inspect the unit for any signs of swollen power supplies, damaged wiring, or cracked plastic housings that may require additional attention. Dispose of any failed components responsibly according to local e‑waste guidelines.
Video Overview
Cut the wires as close to the pump as possible to preserve the length of the wire. The wire connections are covered with glue.
Strip the plastic that covers the wire about 1/8 inch down from the ends until the end of the wire is exposed.
On the circuit board, note which wire is positive and which wire is negative.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
