Up to 20% off select tools
Advent Modena M201 Hard Drive Replacement
Views: 7.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
96
All Time:
7,748
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Parts
Tools
    1. Advent Modena M201 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Remove battery, press power button to ensure complete discharge.
      • Remove all screws on the underside, there are no hidden screws
      Ask FixBot
    2. Advent Modena M201 Hard Drive Replacement: step 2, image 1 of 1
      • Unsnap case , it is best to start at the hinge joints. Work round the case towards the VGA port (RHS). The case needs to pop out over the port so ease the bottom out with your screwdriver. Work round towards the audio jacks (LHS). Lift the RHS of the case up and slide it towards the audio jacks to free them, as the casing cannot be eased over them.
      Ask FixBot
    3. Advent Modena M201 Hard Drive Replacement: step 3, image 1 of 1
      • Remove the two screw holding the hard drive caddy in place.
      • Using the plastic tab , lift the caddy up over the screw pillars and pull gentle to the left to unsnap the SATA connector
      Ask FixBot
    4. Advent Modena M201 Hard Drive Replacement: step 4, image 1 of 1
      • remove the two screw holding the caddy to the end of the hard drive and attach to the new drive.
      • Reverse the process to reassemble.
      Ask FixBot
5 other people completed this guide.
Author
with
Edward
257 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 96
All Time: 7,748
